Proform roller rockers! *** is wrong? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2005, 07:00 PM
Sagacious's Avatar
Do you feel like we do?
i bought a pair of SBC proform roller rockers for my 360 motor. the rest of the engine is not roller. i have a .477 int .480 exhaust cam. i use stock sized hardended pushrods. are roller rockers supposed to sound like a loud sewing machine? i was under the assumption it would be fairly quiet due to the "rolling" nature of it. if so, what is causing the sewing machine sound? also, i notice some wear on the insides of the roller rockers where the nuts are rubbing as the rockers go back and forth. the actual top of the nut is not hitting but the lower part is rubbing on the insides of the roller rockers causing the anodized finish to rub off. why is this? can this be normal? help!
Old 03-21-2005, 07:37 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
is your engine hydraulic cam equipped? Are the rockers adjustable or a pedestal/shaft mount non-adjustable system?
Whatever you do, don't let aluminum shavings go into the engine/crankcase.
Old 03-21-2005, 07:51 PM
Sagacious's Avatar
they dont have any shafts linking them together. they are just stand-alone roller rockers and are adjustable. i have a hydraulic Comp cams Xe268
Old 03-21-2005, 07:54 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Sounds pretty normal for pedestal mount. As far as the rubbing, I would have to venture to say if the rubbing isn't bad enough to scrap chunks outa the aluminum you might have a stud that's not true to the valve centerline. Screw in studs may not be tapped straight or the holes were slightly off center. I'd double check all your geometry's. Make sure you have a good contact pattern on the valve tip. If the rubbing isn't bad enough to scrap chunks, there's not a lot you can do easily or cheaply without head removal. Stud girdles might help pull things in line. Give us more info about the heads and what's been done already.
Old 03-21-2005, 08:05 PM
Sagacious's Avatar
the heads are a #416 casting, they've been cut open to 72cc with 2.02 valves. screw in studs and they have guide plates. i was thinking.. could the rubbing be due to the guide plates needing to be aligned/centered? because if some or all of them are "off" center then they would guide the pushrod in a diagonal direction which might account for the rubbing on the side of most of the roller rockers. just a thought.
Old 03-21-2005, 08:27 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Have you inspected the clearance between the spring's and the rocker?
Noticed any "poping" when turning the engine over during the install?
That's a dead give away for spring interferance.
Seems most of the alum. roller pieces need some working over to play well with the rest of the engine.
Old 03-22-2005, 03:23 AM
Sound's like you are using the stock nuts. My roller rockers came with specially designed nuts that clear the inner structure of the rockers.
Old 03-22-2005, 10:44 AM
Sagacious's Avatar
nope... im using the nuts that they came with. there is just little clearance in between the the insides of the rocker and the nut. the rockers arent hitting the bottom of the nut... just the sides of it. thats only when the vehicle is on and the rockers have play from side to side. none of them are loose but they are able to move very minutely at higher rpms.
Old 03-22-2005, 08:43 PM
Sagacious's Avatar
giving up...
i have since given up on those proform roller rockers. i dont know what was going wrong but i decided to rip them off and go with the stock rockers. at least they dont sound like a sewing machine besides, in a non roller engine i only gain at most 10hp. after taking them off and inspecting them i noticed a few of them were hitting the bottom of the stud as i could see a little bit of aluminum had worn off, as well as the insides being scraped by the sides of the nut. anyway... all is quiet now and the exhaust sounds more even. i guess thats what i get for buying the cheapest roller rockers i could find.
Old 03-23-2005, 10:37 AM
camaroman7d's Avatar
I wish you would have posted before buying the Proform rockers. They are pretty much junk and they are LOUD. The nuts that come with them are TERRIBLE, very poor quality. I ran a set a few year ago and I took them off and got rid of them. If you want roller rockers spend a few extra bucks and get a decent set. The decent ones are not nearly as loud as the Proforms. Don't use the Proforms as a gauge of how roller roskers, sound, fit, or perform.
Royce
Old 03-23-2005, 11:40 AM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
Royce
A little off topic but just a quick question, since you said proform rockers are junk, what woulc you consider to be good brands? I just purchased a set of Scorpions for my engine and I would like to know if they are junk or not before I put them on and mess up a good engine.
Brad
Old 03-23-2005, 12:08 PM
Siggy_Freud's Avatar
I am using some summit 1.6 full rollers and they seem to be VERY high quality. They were recommended to me by trickflow to go along with their heads (along with a trickflow line of rockers).
Old 03-23-2005, 01:08 PM
GoneNova/406's Avatar
i assume that the sound they make is different brand to brand.i have the crane energizer rockers and they also make a bit of a sewing machine sound.i was reading an article a couple of wks. ago i think in the back of chevy high performance,the Q & A section and someone wrote in and asked kevin mcClelland if his were suppose to make noise and that he thought they would be quiet.kevin wrote back and said all r.r.'s make some noise that you can not adjust it all the way out.
Old 03-23-2005, 04:49 PM
4onthefloor 2's Avatar
1968 chevelle
Brad
Im using Scorpion roller rockers on my sbc with no problems but I did have to change to a shorter push rod but they run great and don't make alot of noise
Old 03-23-2005, 05:52 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I have a set of stainless steel Crowers on my Dakota, not a cheep rocker and they make the noise you refer to. The Crowers are self aligning. Maybe the aligning guides are what causes the noise.????
roller rockers or roller tip rockers Jared Engine 18 08-01-2007 01:18 PM
misaligned roller rockers? TVR383 Engine 5 05-31-2004 06:17 PM
Roller Rockers black66 Engine 5 10-23-2003 07:32 PM
Proform roller rockers Anygood? jl_zimmerman Engine 4 01-09-2003 08:43 PM
Proform Roller Rockers and Push Rods???? cl5man Engine 2 11-04-2002 06:45 PM
