Proform Valve Spring Micrometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2012, 06:53 PM
I was happy to find it in my mailbox this evening, but upon opening it, I found that the threads are fubar'ed. There is no way this thing is accurate to 0.001 with these threads. At times you have to force it to turn.
I had heard such good things about them too.
I am regretting saving a couple bucks over the Comp Cams one...
After I ship this thing back, I'll probably have spent more.
Anyone else get a shoddy tool from Proform?
Old 08-06-2012, 08:03 PM
Rare but it happens I ordered a proform deck hight indicator that was totally screwed right out of the box, I ended up sending it back and good thing was it was from summit so they took it back and hooked me up with one from csi whom at the time I never heard of but it is a damn good one real high quality piece
Old 08-07-2012, 08:33 AM
BOY! I wish I could charge people to send back our mistakes. I'd get on the horn, call them up, be nice and take some pictures. Explain to them that you're in a bind, theres a deadline and you'd like to know if there is a local rep that will exchange it because you can't justify the downtime and expense of return shipping. Make sure you have your paperwork: shipper number, model number date and any codes on the package.
Usually they'll work with you to get a replacement ASAP.
Old 08-08-2012, 08:56 AM
302 Z28's Avatar
Generally Proform stuff is pure garbage IMHO.
Vince
Old 08-08-2012, 11:06 AM
Vince
I may be coming around to that point of view soon if they don't make good. It is inconceivable to me that a precision tool like this would be shipped out with a defect this bad. It would have taken a human 10 seconds to test and see the problem.
Old 08-08-2012, 04:22 PM
302 Z28's Avatar
More than likely it was returned by another customer then shipped to you as new.
Vince
Old 08-13-2012, 09:37 AM
I used one on my current build and it worked fine. I backed up the measurements with other devices and it was right on. Like previously posted, you probably just got a bad one or previously returned item. It has happened to be before also with other items......the problem with mail order.
I have a proform on-the-head spring checker that I use also. I took the same batch of springs to a machine shop to double check them and found that the proform checker was accurate also. Just my .02. Regards.
Spring Pocket Vs Spring Size vs valve lenth Help Needed swompz Engine 16 05-30-2012 10:25 AM
broken valve? valve spring is sitting off center from rocker tip. zoomo Engine 63 03-25-2011 08:37 PM
Manifold referencing the power valve on a ProForm 750 race series valleyfirearms Engine 0 01-12-2008 07:39 PM
Beehive Springs/Valve Spring Micrometer ssmonty Engine 4 10-27-2007 04:41 PM
Depth Micrometer Blazin72 Garage - Tools 5 07-01-2007 02:08 PM
