Progress on my chevelle - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2007, 04:01 PM
I have found some time to cut my wheel tubs out to fit the slicks in and smooth the dash and firewall. What do you guys think so far? Can anyone give me the best method to take my axle length measurement to get my rearend narrowed for my wheel and tire combo? Oh and dont worry the car will sit lower then it is in the picture
ID:	19913   Click image for larger version
Old 03-27-2007, 06:48 PM
TailGater's Avatar
Blood, Sweat, and Gears!
Looks good! man those are some big tires!
how low are you going? I think it looks pretty good at the height you have it at in the picture.
Old 03-27-2007, 11:31 PM
I want to go about an inch lower in the rear maybe more. From the pictue you cant see that the car isn't level so I plan on dropping the front. I have some 2 inch drop spindles and the weight of a big block so I should be set. Thanks for the complement
Old 03-28-2007, 08:06 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
You've got it set up to measure already! Easiest way is to set the tires/wheels where you want them in the wheel wells then measure between the surfaces that mate to the axle flange. Give that measurement to the shop that's narrowing the axle assembly, and tell them that's the hub to hub length you want. Make sure you have at least 1/2" clearance between the tire and fender lip and on the inside -- 3/4" is better.
Chevelle vs. Malibu nitro3421 Hotrodding Basics 39 06-18-2014 06:41 PM
72 Chevelle Ss Bodywork In Progress 1972CHEVELLEMAN Body - Exterior 0 10-09-2006 10:09 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 08:52 AM
Help With What To Do With A 66 Chevelle I bought - Trades? daveh Hotrodders' Lounge 17 03-29-2006 05:26 PM
Progress, progress, oh yeah progress Bluepen Hotrodders' Lounge 1 12-06-2005 07:09 PM
