Progress on my Olds 455 powered pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2012, 07:16 PM
Note: This is my long distance project. My truck is in CA, & I live in CT. I fly out every few months & work on it...
This truck has been sitting at my parents house for about 25 years. I don't live in California anymore, so it's been neglected for some time. Over the past year or two, I've been making it a priority to get it running.
One of the things I've been meaning to fix is the engine placement. I installed an Olds 455 just after high school back in 1988. It was a rough installation, as we had to modify a big block swap kit to fit a Olds. Why Olds 455? It's because what I had, & BBC's were too expensive.
As you can see here, the engine is not centered (old mounts make it look worse)
So out out comes the mount. I don't think the neighbors were too happy with me at 1am. My biggest concern was those big spiders though
One of my other goals on this trip was to install a split timing cover. This will make it way easier to install a new cam on my next trip - prob in May.
I got the cover online from a guy who makes them. I modified it by adding another piece of metal in the top half. I wanted to keep the oil from possibly leaking, and also give it a little more strength.
Another goal was to add a marine alternator mount. This places the alt down low on the driver side. I needed to do this now because I was getting the crossmember fixed, & the engine would be lowered about 1.5". You can also see the new split timing cover installed, along with my NOS W-30 2 groove crank pulley
I still have about an inch below the alternator
At this point, I have the newly modified crossmember installed, & the engine is a lot more level
I still want to move the engine & trans back about another inch. I want to fit a full size clutch fan with a 4 row radiator. These valve covers will be cut for firewall clearance & rechromed.
There's a 455 in there...
Hopefully, I may be able to start it up on my next trip out to CA. I'm rebuilding a pair of Carters for my dual quad intake that's gonna go on it
Carb pics & rebuild
Here is is about 5" lower in the front
Until next time,
Old 01-19-2012, 08:15 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
looks good, I cant get stuff done when my car is at home
did you end up pulling it out of the spot it was parked?
Old 01-19-2012, 08:22 PM
No. I used a leaf blower to clear out the multi-legged critters (along with a can of WD-40)
I didn't have enough time to roll it out like I originally planned. I think I'll try using those wheel dollys and move the truck closer to the house when I redo the brakes.
Old 01-20-2012, 05:42 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Not a technical question or post, moved to the Lounge. We encourage you to start a project journal, we've seen a lot more activity there lately, this project would be a nice addition.
Semper Fi
Old 01-20-2012, 08:50 PM
ok, will start a journal
Old 01-20-2012, 08:56 PM
& matts38chev
One of my other goals on this trip was to install a split timing cover. This will make it way easier to install a new cam on my next trip - prob in May. I got the cover online from a guy who makes them. I modified it by adding another piece of metal in the top half. I wanted to keep the oil from possibly leaking, and also give it a little more strength.
are you sure the piece that you added will clear the timing chain?
Old 01-20-2012, 09:52 PM
Yeah, but I will check it again before I seal it on. There's also a button on the cam gear bolt that will hit the timing cover before the chain will hit the piece I added. You can see where the button was hitting the old cover - clean round spot just above the 2 threaded holes
Old 01-20-2012, 10:00 PM
you can see here that the timing chain is fairly deep in there
Air powered or battery powered nailer? HotRodMan Garage - Tools 4 07-26-2010 08:09 AM
LT1 powered RX7 LT1Powered-RX7 Transmission - Rearend 2 01-21-2006 03:48 PM
Progress, progress, oh yeah progress Bluepen Hotrodders' Lounge 1 12-06-2005 07:09 PM
V8 215 olds powered TR6 Marion C Introduce Yourself 1 07-20-2005 07:25 AM
'53 Chevy pickup progress photos willys36@aol.com Hotrodders' Lounge 15 10-18-2002 11:27 PM
