Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Project: 1965 Corvair Kelmark V8 - What motor / recipe?
Old 01-15-2013, 04:17 AM
1Gary's Avatar
1Gary 1Gary is offline
Last journal entry: 383 dyno sym
Originally Posted by mikebuongiorno View Post
Already have engine mounts welded to subframe for gen 1 v8, and have the kelmark adapter for the gen 1 to corvair diff.
Going with a modern block (LSX or otherwise) would require new adapter and new motor mount locations correct? I feel like the car is so close to drivable should press forward with gen 1, otherwise, its a longer term project and if were to change mount location and adapter, would be inclined to change diff and tranny as well.
Could I find the right bump stick for the 350/290 crate that put the torque down under 300, and still give me ~300+ horseys at 4-6k? Any recommendations?
Thinking 600-650 cfm carb, ram horn manifolds (the engine is in the middle of the car).
-Mike
Naw Mike.There are conversion engine mounts from first gen to LSx which are a simple bolt on to the first gen's.So that should be no problem.
Is this a stick shift??. I'm not familiar with your V8's conversion's name.
