Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - project bronco quarters
Old 06-22-2012, 04:54 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
The epoxy sticks like crazy and it seals everything up .you really dont need anything else on the inside ,you can paint it if you want to, but use a SS paint not a base coat...The 2k is for getting your body work straight ,thats basiclly about it. You would want to epoxy before you used the 2k but the SPI epoxy can also be used as a building primer but it takes days to cure ,so if you have the time to wait you can eliminate the cost of a 2k primer and just use the SPI epoxy all by itself....I belive it comes in black, white and gray...
be sure to post pics as you progress....
