project ;; computer updating . - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-04-2013, 06:59 PM
Last journal entry: project ;; garage!!!!
howdy all . working on getting my scanner updated . also trying to set up a harddrive in a laptop . it is pretty flustrating . too much computer junk on these autos now . grew up with the 60s musclecars . guess i am stuck in the past . always had a love for em and probably always will .
Old 02-04-2013, 07:14 PM
poncho62's Avatar
Wiki Edits: 5
I just bought a scanner yesterday...they had them at 1/2 price, so I figured its time to come into the 21st century.......Its a Innova 3100....Loaded the software CD and it said there was an update, which I just did.....I havnt hooked it to a car yet......I am pretty much clueless at this, so will have to learn......
Guess we can learn this stuff together
Old 02-04-2013, 07:35 PM
i been using scanners for a long time . i,ve had my gensys for about 5 years now and have updated it from 2.0 to3.0 . this 5.0 just has so much more crap it is being harder to upload . 58x2 .
Old 02-05-2013, 04:52 PM
LATECH's Avatar
scanners arent too tough . Understanding the CORRECT interpretation of a code is very important
Also understanding the data stream and its components , there basic construction (how they function) and their importance in the system .
I like scanners with Bi directional controls....meaning you can manipulate a certain device by commanding it with a scanner, it makes it fast and easy to rule out wiring issues when you can command a device. If a device doesnt function , run the command and watch the associated wiring for the voltage that the device operates on. If the voltage is correct, the device is bad and the wiring is good. If the voltage is not correct or not present , then the wiring or the PCM comes into play.
Logical and sequential deductive reasoning can be a solid attribute to a fast diagnosis, like when your working flat rate.....
Fact is stranger than Fiction
Old 02-06-2013, 07:07 PM
howdy . thanks guys for the two replys . worked as a gm tech for a while . it was ok , but the crap that they want and have you do is not always or mostly not right . with good equipment ya can get it figured out . just got in from both works . putting a clutch and a reman trans in a freightliner classic xl detroit 60 . 58x2 .
Recent Modern Electronic Engines posts with photos
updating brakes begtadiffer Suspension - Brakes - Steering 3 05-23-2012 09:58 AM
01 Must 4.6L into Project Vehicle Questions with Computer waltrobak Modern Electronic Engines 12 01-11-2012 06:37 AM
? about modifying/ updating stering 49fordp/u Suspension - Brakes - Steering 7 07-21-2009 09:03 PM
updating a chevy vpillusion Suspension - Brakes - Steering 2 04-22-2006 04:41 PM
Updating 55 Olds Ft End Juans55Olds Suspension - Brakes - Steering 1 09-17-2003 08:38 AM
