Get the frame blasted then get an epoxy primer like Dupont . Your local body shop supply should carry it. Put 2 or 3 good coats on and your done. The primer will need to be sanded if you wait more than a day to topcoat with paint. You can shoot all the front end parts with the epoxy as well. Just make sure they are also down to bare metal and clean of grease.
