PROMAXX freedom series - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-24-2013, 04:02 PM
NovaLou's Avatar
The car its going in is a 1969 Nova. I want a street car with above average HP (350-400). Don't know how much its gonna cost to zero deck the block but I can go $400 on Roller cam lifter and springs. I'm just not certain which cam to go with now and from what the Tech said it sounds like things got more complicated after finding out the block was cast #3970010
  #32 (permalink)
Old 05-24-2013, 04:33 PM
NovaLou's Avatar
Filling out the form now. Thanks
  #33 (permalink)
Old 05-24-2013, 05:13 PM
vinniekq2's Avatar
when I overhaul and engine,I spend quite a lot on machine work.Im fussy and have to pay the price. The block gets cleaned(several times if you count thread chasing)new cam bearings and frost plugs.
Machine work is align hone as required,bore as required,finish hone as required,squared and decked.crank gets ground and or honed. heads get resurfaced,valve grind and guides as required.rods are magnafluxed/resized.rotating parts all get "precision" balanced.some blocks require clearancing,,,
The machine shop guy gets a few bucks
The better quality the machining the more the cost,,,
  #34 (permalink)
Old 05-24-2013, 05:54 PM
techinspector1's Avatar
Wiki Edits: 326
Yeah, but the alternative is heads that sit askew on the block, creating different static compression ratios cylinder to cylinder and an intake manifold that won't seal up. You either have the money to do a correct rebuild or you don't.
  #35 (permalink)
Old 05-24-2013, 08:34 PM
NovaLou's Avatar
How much should I expect to pay to have my block zero decked?
  #36 (permalink)
Old 05-24-2013, 08:45 PM
Proud LOSER
Where I am it ranges from $150-$200
The Following User Says Thank You to bygddy For This Useful Post:
NovaLou (05-24-2013)
  #37 (permalink)
Old 05-24-2013, 08:56 PM
NovaLou's Avatar
Is it a must that I deck my block? I'm wondering why the shop that prepared my block didn't do this. I only paid $240 for hot tank, magnaflux, new bearings, new plugs, honed block and polished crank.
  #38 (permalink)
Old 05-24-2013, 09:44 PM
NovaLou's Avatar
I did some research, once I get the pistons I can get piston to block clearance. So it looks like my block will be going back to the shop once my piston arrive.
  #39 (permalink)
Old 02-18-2016, 06:37 PM
Asking for help which kit for Vette L82 1980
Originally Posted by bygddy View Post
The cams your listing are hyd flat tappet.
Tech and Vinnie are 100% right, and read the link tech gave you. If there is any way to swing for a hyd roller then absolutely do it, more power everywhere, and 100% more reliability.
BUT.....if that's not in the budget......and don't get terrified if it isn't, many people are still using flat tappet cams....then may I make a couple suggestions that keep things simple? If your new to all of this (which I'm talking out of my *** and have no idea) then some of tech's info is going to be over your head. He is way smarter then alot of us and knows his stuff inside and out....but its alot to take in..... a 350-400hp 355 is dead simple.....
Summit rebuild kit with 0.030 slugs, get the block zero decked.
0.041 head gasket
Your requested heads
PROMAXX Performance Freedom Series Small Block Chevy Cylinder Heads 2169 - Free Shipping on Orders Over $99 at Summit Racing
Cam
Howards Cams Hydraulic Flat Tappet Camshafts 110991-08 - Free Shipping on Orders Over $99 at Summit Racing
Intake
http://www.summitracing.com/parts/edl-7101
Carb
http://www.summitracing.com/parts/hly-0-4777c/overview/
Comp is 10:2.1, should make the numbers your looking for assuming the published flow numbers Patriot had still stand up.
No reason they shouldn't be the same
Tech? Am I close here....cam straight up installed, 1.5 rockers....?
2500-3000 stall and 373 or better depending on tire, this should be fun.
Oh and use this at every oil change
http://www.summitracing.com/parts/cca-159
Originally Posted by techinspector1 View Post
Smaller carburetor, smaller cam than last Sim, all else the same.
Order the cam direct from Howards and have them nitride it before shipping to you. Install the cam retarded 4 degrees on these 0.050" tappet lift numbers....
Intake opens (0.5) BTDC
Intake closes (40.5) ABDC
Exhaust opens (38.5) BBDC
Exhaust closes (2.5) ATDC
RPM...HP...TQ
2000...146...384
2500...184...388
3000...232...407
3500...284...427
4000...329...430
4500...364...425
5000...385...406
5500...371...355
Peak volumetric efficiency 87.3% @4500
Peak BMEP 186.1 lbs @4000
Nice combination bygddy.
I know that's an old topic however I'm very interested about completing this set.
I got Corvette 1980 L82 looking for street car about 350hp, and regarding for some budget heads + rest of the kit.
Bygddy kit which techinspector1 modification , gives nice effect for me but I'm total new in this things so asking for help.
My question is :
1. Will it gonna fit for my Vette ?
2. Which exactly camshaft should i order ? (techinspector1 specs.)
3. What else do I need for complete this kit ?
I'll be very greatefull for help me which this kit.
Michael .
  #40 (permalink)
Old 02-18-2016, 06:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by Buszmen View Post
My question is :
Michael .
Should be some answers. Thread only 3 yrs old. Many of the members are still active here.
  #41 (permalink)
Old 02-18-2016, 09:00 PM
vinniekq2's Avatar
Buszmen,start your own thread or PM me ? My Corvette is 1981,so all the snakes in your way I can help you avoid some,,,
Patriot Freedom Series heads prostcelica Engine 17 07-26-2012 04:27 PM
Freedom of religion, freedom of speech and freedom of self-expression... Blazin72 Off-Topic 19 02-10-2007 01:48 AM
Freedom 48ChryslerRodder Hotrodders' Lounge 0 07-04-2006 01:14 PM
Freedom.... Kevin45 Hotrodders' Lounge 2 08-03-2005 03:38 PM
Freedom at last! 53fordguy Hotrodders' Lounge 11 10-26-2004 09:56 PM
