Proper adjustment of idle screws. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-08-2010, 03:32 PM
aintmisbehavinn's Avatar
Jesus loves you I don't...
Originally Posted by bubbahotep
Push the accel pump arm down quickly by hand without actually giving it throttle is going to shoot gas onto the top of the primary blades
Try it, it worked for me. I am running mech though. One shot to much will flood, it the motor idles up, you are lean. IF nothing, you should be in the ballpark, start looking somewhere else...
If you do not want to register, fill this field only and the name will be used as user name for your post.
6-71 blower trouble msggator Engine 66 12-05-2009 08:20 PM
Blower Motor - Timing - Spark Plugs: Need Clarification Please 41willys Engine 22 08-31-2008 10:01 AM
Mighty Demon and ignition timing rsk289 Engine 34 07-03-2008 02:02 PM
Is this the idle speed adjustment screw on my Edelbrock Qjet? Porschev Engine 4 03-02-2007 07:44 AM
idle mixture screws 72Orange Engine 14 09-28-2006 01:30 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
