proper camshaft for a 327 chevy??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2003, 07:04 AM
New Member
Post proper camshaft for a 327 chevy???
i am putting together a 327 chevy for my 30 ford coupe. i am not going to race, and i am staying with hydraulic lifters. i want a strong motor with good sound. i am running an offenhauser intake with 3 carbs, block bored .30 over. what would be the best cam for this set-up? thanks! mike
Old 02-15-2003, 02:22 PM
MI2600's Avatar
Member# 3287
Post
I'm partial to the 327/350 Chevy cam. It's a hydraulic with 222 degrees @ .050 and .447 lift. You can find them on EBay. I've seen a guy selling the whole cam change outfit for under $110. I haven't really checked though to see if it's a name brand cam and lifters.
Old 02-15-2003, 03:35 PM
Post
Crane is making an improved version of the Corvette 327/300HP motor and it is nice. It is a dual pattern. Unfortunately, I can not find all the specs, but I'm sure if you call Summit racing and ask for the specs on the Crane Energizer for the Corvette 327/300HP, they will have it for you. The before mentioned 350 HP cam is for a high compression motor whereas the 300 version is for lower compression. I'm running it in a 9.5 to 1 , 30 over 327, Bowtie dual plane highrise with a near stock Q Jet and it's nice in a 36 Ford Coupe.
Trees
Old 02-15-2003, 09:46 PM
abe abe is offline
Post
the original 327 ci, 300 horsepower cam is a hydraulic lifter with 398" lift on the intake, 410" lift on the exhaust with 112 degree lobe seperation. Its the same cam used in the 250, 270 and 300 horsepower 350 engines up to 1971. Its a good little cam.
Old 02-15-2003, 11:42 PM
E.T. divided by $ spent= Speed
Post
What are all your specs?? motor(CR,heads,headers etc..)rear gear and a rough idea of tire size,tranny,type and stall converter(if auto)
Old 02-18-2003, 10:43 AM
Thumbs up
I like the 350 hp /327 factory cam.This is the smallest cam I would use. I use one in a 283 balanced with flat tops. With 292 gears, 4 speed and a Q jet got 28 miles per gallon and could tac 9,000 in a 68 chevelle. Pulled the wheels off the ground shifting to second at 70 mph. Nice cam!!!
Old 02-18-2003, 02:38 PM
48fordnut's Avatar
Post
I am looking for this cam, help me with the one on the net. thanks
Old 04-27-2008, 08:10 PM
the right cam for a 327
call crane cams ask them for the 327/350 hp cam number they can give you all the specs and part number
Old 04-27-2008, 08:25 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
I have the Alliance Cams version of the 327/350 cam that I found last week while cleaning the shop. I will be happy to make someone the proud owner of this cam. It's new in the box. If you are interested, PM or email me.
Barry
Old 04-27-2008, 11:19 PM
12-672-4 try this cam its a comp cam I've used it before in a 327ci and its a little nasty but ran it with 10.35:1cr and brodix 170cc aluminum heads,it was in a 67' camaro with a tko 5 spd
Old 03-29-2011, 08:24 AM
proper camshaft
I thought about putting the l79 327/350 hp cam in my 327 but I also thought about the comp L79+ cam it comes in at 1800 to 6000 or 6200 where the original 342/342 222/222 447/447 L79 cam comes in at 2200 and goes out at 5800 both cams are just as good thou the comp cam has improved sound and is supposed to have better power.but the original has good power and nice to listen to the old heguda heguda note theres nothing like the old muscle car sound it produces . let me no if you decide to go with the comp cam Id like to no how the improved sound is if it sounds and performes better than the original It should be realy nice.
Old 03-29-2011, 09:18 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
yeah use this one
Old 03-29-2011, 10:55 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Originally Posted by Custom10
yeah use this one
292 gears? Pulled a wheelie? 283? Must have been a granny 1st gear
btw, this is an old thread.
Old 03-29-2011, 01:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Old 06-12-2011, 07:50 AM
55_327's Avatar
Funny. I just Googled "327 350 cam" and found this thread. Almost fell out of my chair laughing while reading about the wheel-standing, 9,000 RPM 283 with a hydraulic lifter cam.
On to the subject of the thread: A modern version of the 327/350hp cam is GM# 24502476. Intake duration is shorter and LSA is tighter so it will work with lower compression (probably 8.5:1 -9.5:1). The 60s version was designed for 11:1 advertised, 10.5 actual, as I recall.
Details here: http://www.summitracing.com/parts/NAL-24502476/
And here's an oldie but goodie for a 327 or 350: Erson Viking 100H #112061. It's 222/222/108, .447"/.447" and should work well with 9.5:1, probably even 9.0:1 when advanced 4 degrees. Power band will be a little narrower, but will have a strong hit, so it would be a good fit for a 4-5 speed manual trans. And I'd use 1.6 rockers with modern heads, or 1.5 rockers with 60-70s cast iron heads. Idle should sound pretty cool with the 108 LSA, but gas mileage will probably suck.
