proper driveshaft length
I need to set up a driveshaft for a 700r4 to an 8.8 rear. I have to find a driveshaft from the wreckers and take it to a machine shop to put the rear u-joint on. I'm wondering how far in the sleeve of the front yoke should be slid into the tailshaft when I figure the length. Presently there's no body on the chassis so the rearend is sitting higher than it will sit with the body weight on it.
If you have a tailshaft yoke slip it into the tranny. Shove it in all the way and then pull it out about an 1 1/2. This will give it the required wiggle room. Measure between the u-joint centerlines for shaft length.
Mark |
I guess I'll put a couple of big guys on the back end, pull the yoke out 1 1/2" and measure. Thanks guys.
| figuring length of driveshaft | murrsue | Transmission - Rearend | 5 | 02-19-2005 04:00 PM |
| wrong driveshaft length? | darom | Transmission - Rearend | 16 | 03-23-2004 07:59 PM |
| TH400 Driveshaft length | mark2002 | Transmission - Rearend | 4 | 11-22-2003 08:46 AM |
| Driveshaft length ??? | Pinto_Guy | Transmission - Rearend | 3 | 09-04-2003 01:55 PM |
| Nova Driveshaft Length | 68NovaSS | Transmission - Rearend | 2 | 01-20-2003 09:19 PM |
