Proper Master Cylinder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 05:53 AM
31ROC's Avatar
Hi, I have a 31 Model A rod, it has 11" drum brakes rear, and disc up front. These are manual, and I want to be sure the master cylinder was correctly sized for this car. I have soft pedal, and want to start from the beginning eliminating each possible senario which would cause this issue....(just purchased car)...Thanks in advance.
Old 04-22-2012, 04:23 PM
BOBCRMAN@aol.com's Avatar
Soft pedal can be from many variables.. Usually air trap. What front brakes? Are the bleeders in correct position? I have had setups come in that had to be bled with caliper/ cylinders unbolted from the car, using a dummy rotor. Proportioning valves? Residual valves? Present master size? Many people use a master with too large bore. Keep it under 1" for light car. In many cases. The smaller the master bore, the more pedal force to the wheels.
Old 04-22-2012, 04:54 PM
LATECH's Avatar
If it has the underfloor master setup you most likely will need to have residual valves as well.
Old 04-22-2012, 05:36 PM
31ROC's Avatar
I will have to look for these answers, since I've had the car for only a week or so.
Old 04-22-2012, 05:37 PM
31ROC's Avatar
It does have under floor master, but no clue if there are porportioning and residual valves....where SHOULD they be located?
Old 04-22-2012, 06:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here is a page on brake valves. If you have an added on residual pressure valve(s) it can be in the brake line anywhere between the master cylinder and the caliper/slave. You can also have a built-in residual valve. This can be in the MC itself or in the combo valve if equipped w/one.
Old 04-22-2012, 08:36 PM
New Member
master cylinder doug1933 Suspension - Brakes - Steering 1 09-06-2011 03:24 PM
Proper Way to Store Newly Rebuilt Cylinder Heads Dougie Engine 4 01-10-2011 08:59 PM
master cylinder to use? barnym17 Suspension - Brakes - Steering 21 05-30-2009 06:57 AM
Master cylinder 49dream Suspension - Brakes - Steering 3 06-25-2006 05:23 PM
Master Cylinder 46_stvblt Suspension - Brakes - Steering 3 08-24-2005 10:54 AM
