Proper PCV routing for early 350 chevy V 8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2011, 08:12 PM
Not sure about how to route the hoses for the PCV system on my Nova's 350 V-8. I'm getting blow by out of the breather caps and i'm sure it's not hooked up correctly as i've done nothing but fix a lot of mistakes on this ride since i got it home.
Old 05-16-2011, 10:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
HERE is a link to a diagram of a basic PCV system.
Generally speaking, the PCV valve goes in one valve cover and is routed to the base of the carb where there is usually a port for this purpose. The other valve cover has a fresh air intake that draws filtered air from the air filter housing or a separate filter.
Old 05-19-2011, 02:50 PM
pcv valve routing
Thanks for the tip, i think i know what to do with it now. The routing on my power plant was correct coming from the pcv breather cap to the base of the carb,but the guy i bought the car from ,did'nt hook up the breather on the other side of the valve cover to the air breather. Thanks again
Old 05-19-2011, 03:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You are quite welcome.
To clarify, you can use a filtered breather on the opposite side from the PCV valve- it doesn't have to have a hose to the air cleaner housing, necessarily- but there does need to be something that will allow filtered air into the opposite side fron the PCV valve.
Good luck.
proper camshaft for a 327 chevy??? straycat60 Engine 23 06-14-2011 05:19 AM
Proper carb fuel line routing? staleg General Rodding Tech 5 10-24-2009 09:01 AM
chevy 305 drive belt diagram/routing rack Engine 2 11-20-2008 12:00 PM
proper vacuum hose routing for a 350 zz3 crate motor sznsjd Engine 1 08-03-2006 11:08 AM
318 into an Early Chevy 73super Engine 5 02-03-2006 08:09 PM
