Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Proper Piston Groove Cleaner Instuctions Please
Old 08-28-2009, 10:20 PM
garyroushkolb's Avatar
garyroushkolb garyroushkolb is offline
Last wiki edit: How to find an electrical drain Last photo:
I've had that happen also, what I decided was that it was taking metal off the inside of the ring groove and not making it wider. Home depot has a cool lighted magnifier that you can use to see for your self. I don't thinks it's a problem unless you take alot of metal out. What you don't want to do is scrape the lands wider as that will make the rings flutter.
