Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Proper pressure setting for pressure pot supply?
Old 03-06-2012, 11:20 AM
777funk 777funk is offline
Originally Posted by shine
shut the air down to the pot after spraying. adjust before you start.
That should do the trick. Great idea shine. I usually spray a coat, wait an hour and do another coat. That waiting an hour part is when the pressure tends to creep up. If I come back for the next and don't check the regulator/pressure that's where I'm running into problems. I'll try shutting the air off between coats. I wish there was a regulator that was accurate at very low pressures. I'm guessing if there is, it's $$$.
