proper stud installation...? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2003, 06:21 PM
nastynova's Avatar
Post proper stud installation...?
whats the proper way to install head studs and main studs...?
I've heard different things.....whats right?
Old 04-07-2003, 06:26 PM
BOBCRMAN@aol.com's Avatar
Post
use manufacturers recommended lube and finger tight in the block on main studs, use recommended sealer(I use teflon paste) and finger tight in deck on head studs.(For Chevys)
[ April 07, 2003: Message edited by: BOBCRMAN@aol.com ]</p>
Old 04-07-2003, 06:35 PM
nastynova's Avatar
Post
Thanks...If you pull a head, should re-install the studs...? or will they stay sealed?
Old 04-07-2003, 07:24 PM
Post
I would re seal them,
Old 04-07-2003, 08:00 PM
4 Jaw Chuck's Avatar
Post
I clean and then red loctite the studs once they are bottomed finger tight. All aircraft engines are assembled in this fashion so the stud will not rotate on disassembly.
— Han Solo
