Proper Tire Pressure ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2002, 03:48 PM
Post Proper Tire Pressure ??
I was looking through my 1976 Monte Carlo Restoration packet and they recommend inflating the Original GR 70-15 tires to 28 PSI. I have 225-70-15 tires on the Front and 245-60-15 tires on the Rear. Will 28 PSI be enough pressure ? The car weighs 3900# with 116" Wheelbase, 350 CID Thanks
Old 06-23-2002, 06:49 PM
4 Jaw Chuck's Avatar
Post
A tire maximum load rating is reached when the tires are inflated to the maximum rated pressure stated on the sidewall. If you want to run them higher or lower it will affect the wear of the tire at maximum load, everything in between is up to individual preference and your need for a comfortable ride.
Personally I like them a couple of psi above the maximum rating but only because it gives a firmer ride and hence better handling. let your tire wear and likes dictate what you prefer, 28 psi will work just fine.
At our local track no street car is allowed on the track without 40 psi minimum in the tires because the cornering loads have a tendency to shred tires at lower pressures. Any tire pressure is only a recommendation not a requirement.
— Han Solo
Old 06-24-2002, 04:08 PM
Cool
Thanks 4 jaw chuck.
Bigjoedo
« Chevy II | 48 Chevy »
