Proper TV cable installation on 700r4? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2008, 06:42 AM
I am installing the TV cable on my 700r4 and was wondering if someone could walk me through the correct procedure to mak sure that I get it installed right. The connection inside the tranny is in the shape of a "c" but the end of the TV cable will not slip over the first bend in the connection. Really could use some input on this one guys don't want to burn up this tranny.
Thanks,
Alan
Old 04-02-2008, 07:48 AM
daledove's Avatar
I don't think it needs to go past the bend. Mine didn't anyway. Just slide it onto the connection and pull it tight while pushing the housing into the trans, then tighten the holddown bolt. The connection at the carb is the critical connection.
Old 04-02-2008, 08:07 AM
So it won't slip off the connection in the tranny?
Old 04-02-2008, 11:30 AM
daledove's Avatar
No, it actually gets pulled up into the barrel portion of the cable.
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Need Help, adjusting a lokar tv cable maninacoupe Transmission - Rearend 2 10-01-2006 06:25 PM
700r4 TV CABLE installation or calibration ss crazy Transmission - Rearend 2 04-07-2003 08:20 AM
