Proper way to install heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2002, 07:10 PM
Post Proper way to install heads
My engine guy told me i would void my warantee if i install the heads incorrectly. What should i be aware of that i can screw up, i am following my haines manual. I would like some tips please. i am installing factory heads onto a rebuilt chevy 350. Its a 79.
thansk alot
Old 10-14-2002, 07:23 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Is he the one giving the warranty on the heads? Did he warn you of any possible things that are NO NOs? Just follow the manual and you almost CAN'T screw up. But if something goes wrong, and you have to go back to the guy, ADMIT NOTHING DENY EVERYTHING AND IMPLY COUNTER-ACCUSATIONS! This has always worked for me!
Old 10-14-2002, 07:31 PM
E.T. divided by $ spent= Speed
Post
If its stock just install new gaskets make sure you have um face up if they are marked face up other wise put um label up.There will be two medium lenght head bolts put these in the lower corners(17,14) under the valve covers.Put the shortys along the outside edge and long bolts in the rest. Then tork the heads to 1/2 of spec (45 if its 70)etc..Then torque um to full torque.Then drop in the pushrods install the rockers.When adjusting the valves the warrenty probably wants you to adjust um on the stand(I adjust um wet so I dunno).
Also retorque after a little while of run time.
Old 10-14-2002, 07:37 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
Post
you have some good advice already those manuals are pretty good so you should be ok i will stress what monte said and tourque to 45 first then to full spec, read twice screw once, good luck
Old 10-14-2002, 07:41 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
But seriously, if the intake gaskets have a water port restrictor, make sure these go in the back of the motor. You will have major problems if they block flow to the thermostat. If you follow the Haynes manual (don't do any short-cuts) you should be fine. He cant argue too much about any warranty disputes if you follow the manual. Although Haynes and Petersons really suck for anything in-depth, they are really good for jobs like this.
