I like spraying them down with Marvel Mystery Oil. It adheres much better than WD-40. WD-40 works great if you remember to recoat it every week or so, but that can be a PITA over time. It also helps to place them in a heavy plastic bag (a contractor garbage bag works well) and then place them on a thick sheet of rubber to prevent them from being grounded.
AP gave good advice. In a pinch I`ll get a small trash bag, spray the inside down with WD40, the tie the bag around the head. When you go to use the heads it would be wise to relube them as over time the lube can dry out.
It was some years back we had a set of heads overhauled with new guides, valves, the works. But due to winter, and lack of funds to finish on my friends part, the heads sat at the machinists shop many months before they were used. I called him and asked him to relube them as we would be picking them up in a few days, he assured me he would. Make a long story short, he didn`t. The exhaust valve in the number 2 cylinder seized in the guide from lack of lube. In another incident. I took my Vortec block to the machine shop, he mic`d it and said it was .001, I said fine, hone it and I`ll run it. Since he`s always did good work, I didn`t check the bores when I got it back. which proved to be a costly mistake. The rings never seated and it smoked like a steam train. I got the heads off and checked the bores and found them at 4.009. How in the world he honed them that far out is still a mystery to me. So I learned a lesson, no matter who does it, always check afterwards, the one time you don`t is the time you get bit. |
I oil mine down real good and then wrap them in clear plastic and go around them real good with some duct tape. JMO
Cole |
Spray the bare metal surfaces with Rust Check or engine storage spray.
WD-40 will show flash rust on bare metal after about 10 days. not good. http://www.rustcheck.com You'll find lots of uses for this stuff. |
If your going to put them in a bag then you might consider getting all the trapped air out of the bag. That trapped air can condensate water from the air when the temp changes. You can combat this by emptying a can of computer duster (nitrogen and very dry) into the bag before closing it up.
I would just sit them on the ends in a dry place in the corner, cover em up so they don't get dusty but do not seal the bag. You do not want to trap moist air in there. |
| newly rebuilt quadrajet problem | dawg | Engine | 2 | 08-27-2009 04:41 AM |
| Newly Rebuilt SBC 283 | Wadeamca | Engine | 8 | 03-13-2009 07:53 AM |
| Newly rebuilt 327 shudders & other ??'s | dirtslingerrc | Engine | 9 | 09-06-2006 10:21 PM |
| Whats the best way to store my new Dart heads? | batman09 | Engine | 3 | 02-13-2005 09:55 PM |
| Oil Not Pumping To Top End On Newly Rebuilt Engine | MrReaves | Engine | 13 | 12-20-2003 10:33 PM |
