Proportioning Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2011, 09:52 PM
Proportioning Valve
On my '37 Ford coupe I have power disc brakes in front and drums in rear. If I hit the pedal too hard the rear wheels lock up. There is no proportioning valve, and I think that is the problem. If so, is it as easy as it looks to install one of the universal adjustable proportioning valves? Looks like I would simply cut and double reflare the brake line to rear wheels and screw the line into the valve. Is that about it? What do I need to check to be sure the brakes work right after the valve is installed? I'm looking at a Willwood valve. Any comments are appreciated. Is there a recommended psi number to shoot for?
Thanks
Old 07-19-2011, 11:01 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The installation is simple enough just put it where you can reach it from the driver position. Only way i know to set one is to try it starting at a slow speed say about 20mph and adjust it to get the brake bias right and then try it at higher speeds. the ideal is that if you need to dynamite the brakes at 80 on the freeway the car stays straight while stopping..
Sam
Old 07-20-2011, 02:24 PM
Proportioning Valve
Sam, thank you for the reply. However, it is not possible to put it where you suggest, but I will be able to adjust if needed as you describe.
Jim
Old 07-20-2011, 05:47 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
I don't think you need to put it within reach of the driver, just mount it somewhere protected from road debris and you can reach it without too much hassle. Under the hood is fine.
Start your adjustment process with full pressure to the rears and test at low speeds in a gravel lot. That makes it easy to see which end is locking up first. As speed and confidence increase move to a paved parking lot and then to the road. Make sure to test at freeway speeds when you think you are done to see how it does at speed. Also remember that Wilwood proportioning valves operate so turning the knob out (counter clockwise) reduces rear braking, and turning it in (clockwise) increases it.
Andy
Old 07-20-2011, 08:24 PM
Irelands child's Avatar
This is how I mounted mine - the photo makes it look close to the exhaust hanger, it isn't. It's well protected and easy to reach - as long as you are laying on the ground . It should only require a couple of attempts to get it right but it usually will "fix" lock up:
(and before anyone asks, that flex fuel line is gone now as well, replaced w/SS tubing)
Dave W
Irelands child
proportioning valve mac350 Suspension - Brakes - Steering 4 09-28-2010 05:21 PM
Proportioning valve ztoy Suspension - Brakes - Steering 6 06-11-2003 01:55 PM
Proportioning valve 56don Suspension - Brakes - Steering 1 05-09-2003 09:34 AM
pin on proportioning valve andybird Suspension - Brakes - Steering 10 04-17-2003 09:48 AM
S-10 Proportioning Valve TurboS10 Suspension - Brakes - Steering 5 01-03-2003 10:42 AM
