proportioning valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2006, 01:13 PM
DEUCE
proportioning valve
is there a special tool to let pressure threw a proportioning valve on a gm?
i am working on a 67 camaro, and when i put on a pump it just sticks on 20-25 psi.
Old 09-15-2006, 02:02 PM
aka Duke of URL
Are you referring to pressure bleeding the brakes? Is it the proportioning valve (to rear brakes) or the metering valve (to the front brakes)?
So what is a valve job............? machine shop tom Hotrodding Basics 6 02-15-2006 10:25 PM
proportioning valve question A/G WILLYS Suspension - Brakes - Steering 1 10-10-2004 08:38 AM
master cylinder and proportioning valve? curtisstarlight Suspension - Brakes - Steering 3 03-18-2003 10:12 AM
S-10 Proportioning Valve TurboS10 Suspension - Brakes - Steering 5 01-03-2003 11:42 AM
Residual Pressure Valve?? Dave E Shank Suspension - Brakes - Steering 1 12-27-2002 08:12 PM
