-   -   Proportioning valve or block? (http://www.hotrodders.com/forum/proportioning-valve-block-218126.html)
Vetteman61 04-13-2012 08:47 PM
I'm wondering what to go with.
I have 4 wheel disc brakes on a '37 Chevrolet. I have seen some people just run a rear proportioning valve with a knob to turn and others run a block that both the front and rear lines run into.
What are the benefits of each or which one is best?
Thanks,
Brandon
milner 04-13-2012 09:37 PM
it really all depends on weight of vehicle, size of motor, etc. some builders do not use them at all. my advice would be to install one in the rear brakes, that way you can fine tune the braking system to your liking.
Vetteman61 04-13-2012 10:35 PM
Ok, thanks. I'll go that route.
Brandon
