Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Proportioning valve hook up
Old 07-06-2011, 11:43 AM
joe_padavano joe_padavano is offline
Adapter fittings for inverted flare connections are readily available, but the one in your pictures is not the correct one for this application. Note how small the tapered area is on the nose of that fitting. It won't seal on the flare in the prop valve. You need a Weatherhead WH7909 adapter fitting. NAPA should be able to find one for you. These are called "dual master cylinder adapters" by some suppliers. Here's another source:
http://www.hydraulicstore.com/index....mcode]=1053135
