Proportioning valve lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2012, 06:52 PM
Ok guys so i found out what was wrong with my brakes...my master cylinder was out and my proportioning valve is messed up as well.....For the proportioning valve, I found one listed below for $90....But then on summit racing i found one for half that price without the lines (also shown below)..where can i buy these lines and what are they called so i can save some $$$$? Thanks!
its a 1979 firebird BTW
http://www.ebay.com/itm/Chrome-Boost...ht_2127wt_1037
http://www.summitracing.com/parts/CL...RD&prefilter=1
Old 05-12-2012, 12:24 AM
Make the lines yourself. It isn't hard to bend or flare. The hard part can be finding the right nuts to put on before you flare it. I bet Summit carries them.
Old 05-14-2012, 06:44 PM
lines for portion valve lines
Nappa carries all your lines, ever try the bone yard there a third of the cost for the valve, when bleeding don't forget to vent the pressure relief port to balance the internal shaft
Old 05-20-2012, 03:32 PM
hulk347's Avatar
bought this from eastwood,,,,work great,worth every pennies
http://www.eastwood.com/professional...ring-tool.html
Proportioning Valve rusty duck Suspension - Brakes - Steering 4 07-20-2011 09:24 PM
proportioning valve mac350 Suspension - Brakes - Steering 4 09-28-2010 06:21 PM
proportioning valve TROLLMAN Suspension - Brakes - Steering 1 09-15-2006 02:02 PM
proportioning valve 2manyhobbies Suspension - Brakes - Steering 4 02-18-2006 04:06 PM
proportioning valve fred56 Suspension - Brakes - Steering 11 12-21-2005 03:46 PM
