proportioning valve mounting?
I just purchased an adjustable proportioning valve. I'm thinking I should mount it along the top of the frame below and and to the front of the master cylinder. I want to keep it out of the way of the clutch linkage. Is the frame mounting the recommended way? Thanks in advance, Rod
What are you working on Rod ? Sounds like you have it figured out.
Cole |
Frame mount it or make up a bracket mounted to "something" that doesn't flex differently then the brake tubing. It goes in the rear brake line (usually)
Thanks to eloc431962 & Irelands child
Thanks for your response, guys. eloc, it's a '39 ford two door sedan on an S10 frame. I was concerned about keeping the lines and valve away from the clutch linkage. Irelands child, did I understand you to say the the valve should go in the lines going to the rear? I was going to mount it at the frame in front of the master cylinder. Does this make sense? Thanks again, Rod
But yes, the prop does go in the rear lines. Dave W |
On my DEUCE chassis
to the rear brakes.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Another proportioning valve question
Hi Irelands child & Deuce, thanks for the diagram, Irelands child, and for the picture, Deuce. I have a proportioning valve that has inlets and outlets for the front and rear, just like the stock brakes were set up. It has a front in and out and rear in and out. I even found a good place on the frame to mount it. I think I'm on my way. Thanks so much, Rod
That sounds like you have a stock Ford proportioning valve. Does it look like the one in the attached picture?
Read the attached link to bring you up to speed on these valves. http://www.mustangmonthly.com/techar...kes/index.html |
Read the attached link to bring you up to speed on these valves. http://www.mustangmonthly.com/techar...kes/index.html or: http://www.streetlegaltv.com/forum/w...ents-4142.html |
Thanks alittle1
Hi alittle1 and thanks for your suggestion. No, it's a Wildwood proportioning valve and, genius me finally decided to look at the stock S10 master cylinder that I had put up a long time ago. Lo and behold, a bracket for the proportioning valve that mounts on the same bolts as the master cylinder! Great! I had to modify it a touch, but it will work great. Thanks for your reply, Rod
| proportioning valve | mac350 | Suspension - Brakes - Steering | 4 | 09-28-2010 05:21 PM |
| Proportioning Valve Mounting | monk250 | Suspension - Brakes - Steering | 7 | 03-13-2008 05:41 PM |
| proportioning valve | fred56 | Suspension - Brakes - Steering | 11 | 12-21-2005 02:46 PM |
| Proportioning valve | 56don | Suspension - Brakes - Steering | 1 | 05-09-2003 09:34 AM |
| pin on proportioning valve | andybird | Suspension - Brakes - Steering | 10 | 04-17-2003 09:48 AM |
