Proportioning valve and steering box question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-13-2014, 06:14 PM
life is a temporary assignment
Originally Posted by Tacuff1414 View Post
What is a JY prop valve? If I could get away with not using anything but a T, I would. You guys are saying it's a MUST to use some type of prop valve? Why are some other car guys I've been talking to saying I don't need one at all? My buddy that's been helping me out with my rat rod is building a 47' ford truck with disc brakes and said it came from the factory without any kind of prop valve. Why would I have to have one?
Not to sure why your asking here if your buddy know's.. Coming here asking for help and not taking what is told to you is something else.. Don't try to re-invent the wheel here...Do what you feel you must do.. I said way more then I should have...I'm done here.. Good luck.. Remember your life and other people's lives are on the line here..
  #17 (permalink)
Old 02-13-2014, 06:32 PM
LATECH's Avatar
JY = Junkyard
You don't necessarily need a metering valve to keep the front from applying too soon, or a prop valve to keep the back from locking up .
A well balanced braking system can be easy but it wont be as simple as a just putting in a "T" for the brakes.
The metering valve is mostly for wet or Icy conditions to keep the fronts from activating too much and too soon, which could cause a spinout as someone mentioned before.
Also the rear brakes generally take about 25 percent of the braking pressure to activate the brakes compared to the pressure to activate enough clamping force on the front disc brakes to create an equal (or close ) amont of friction to create equalstopping force.
Do what you want, when or if it doesn't pan out , you can come back to the thread and reference it for any trouble you may have.
The combination block has the prop valve built in, and a safety valve, in the event that one set of brakes goes bad it shuttles the inner valve to block the system that has failed to allow the other system to remain functional. A safety thing.Kind of a good thing.
Do your homework on your braking system. Then get busy. Its best to understand how it works, so you can make the right choices.
Fact is stranger than Fiction
  #18 (permalink)
Old 02-13-2014, 06:42 PM
I only came here for further advice about my situation and to figure out why I'm getting different answers about it. Thanks for all the info and advice, I'll probably look for an adjustable prop valve or metering valve and try it out.
  #19 (permalink)
Old 02-14-2014, 04:57 AM
Banned
Valves
Call several different brake system manufacturers and ask them for advice. They do it for a living. The braking advice I've seen here is scary. Fact is I probely wont give any more advice at all on brakes, would hate to be the cause of a problem. Joe blows system and your system are two different things. What worked on one might not work on another. I say call several because there are some fly by night guys out there, go to established buisneses. Like was said your life is on the line along with your family.
  #20 (permalink)
Old 02-14-2014, 07:08 AM
Thanks again for all the advice.
Is there a certain adjustable proportional valve I need, or would all
function the same no matter which one I was to get? I noticed Wilwood
was a popular choice...
  #21 (permalink)
Old 02-14-2014, 10:53 AM
S10xGN's Avatar
Gotta love a turbo!
This is the internet after all. I've learned to look at all the responses, whittle those down to the top couple consistent replies, then research those further away from the forum...
Russ
  #22 (permalink)
Old 02-14-2014, 02:28 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
i use the s10 brake system on many . if you do not put a valve in you will regret it. your using an s10 frame why not use the correct brake system . a system with no valve is one hard stop away from disaster .
  #23 (permalink)
Old 02-14-2014, 02:46 PM
I'll definitely get one. My brake booster is off a Ford Ranger (only used it
because I got it free from a friend). I figured with the trucks being about
the same size and all that it wouldn't matter. From what everyone is saying
it's looking like an adjustable valve would work best. I can easily get one
off a Ford Ranger though.
  #24 (permalink)
Old 02-14-2014, 03:00 PM
shine's Avatar
SPI Thug
you can pick up a complete s10 system for 20 bucks or so . i use the pedal and all.
Name:	s10 brakes.jpg
  #25 (permalink)
Old 02-14-2014, 03:02 PM
Where??? I've been to junkyards around here and they want 60-100 dollars for just the brake booster and master!
  #26 (permalink)
Old 02-14-2014, 03:05 PM
shine's Avatar
SPI Thug
i have a couple of guys who collect and crush . every time they get an s10 i get the brakes and the steering column . i pay 20 bucks for the brake system. 20 for the column. i dont shop at salvage yards , they want way too much. they sell parts. my guys sell scrap steel.
  #27 (permalink)
Old 02-14-2014, 03:09 PM
Gotcha. I'm going to keep looking around for an s10 system then.
I'll just switch it out with the ranger one I have on there and used
a proportioning valve and booster from an s10 if I can find one.
steering box question: HELP choirboy Suspension - Brakes - Steering 21 12-13-2008 06:17 PM
proportioning valve question ScottRods2945 Suspension - Brakes - Steering 1 07-01-2007 06:52 PM
Proportioning Valve Question 37FordLS6 Suspension - Brakes - Steering 3 05-29-2006 08:43 AM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 04:14 AM
proportioning valve question A/G WILLYS Suspension - Brakes - Steering 1 10-10-2004 08:38 AM
