Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Proportioning Valve is stuck
Old 01-13-2011, 08:41 AM
Footstomper Footstomper is offline
Last journal entry: 40 ford/cadillac coupe
8 years, I got the proportion valve off a 73 bonneville
It is a cast iron. I put some disks on front and 9" rear 3.70, ford master cylinder. worked for years. 1940 coupe (pictures) on profile. I had a 305 with saginaw overdrive. Now, I have a 500 cadillac with TH400 and beefed up the MMII, boxes. As orginal as I can inside and out.
I had to replace the ford master to a corvette master. The front was working fine, until when I rolled on a rack to alignment, it was raining that day and I was scared becaused the man working on it. So I went very slowly, the rear was wanting to go (I realized no brakes). The guy working on it, I had the front disks wanted to stop (ECI) 5/1/2" for the 40 16" originals all around.
The master seemed to work. The rear would with a fight just to get hydraulic to the rearend. I stomped on the brakes, it is manual. that's my Footstomper name.
A friend told me to go to the junkyard, we have snow, so I got in the garage and pulled the proportion valve last night. I cleaned it as the best I could, I used some air through orfications. The rear side had a fitting and on the front side had a pin, I did tapped alittle. The rear side came out pipe brass with a "O" ring. I got a allen wrench and wd-40, I cleaned it and air began moving. I put all the lines (about all the bonneville had, at least 6 lines). It was cold, and I will have to try it today. I have the car up on stands, and when someone to look at the right tire whether if it stops (I hope), if it keeps rolling with make me mad!
The Following User Says Thank You to Footstomper For This Useful Post:
dan scoggins (07-30-2014)
