proportioning valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2003, 03:38 PM
Question proportioning valves
hello all, im a new poster to the site but have visited it often.
well my questionn is, I have a 1968 Ford Torino 302, drum brakes all around not power, i need a new proportioning valve but cant find one, i want to know if the is any other cars that would work on my application or where i can find a new one.
also i found a pro. valve of a 69 mustang with power drums, would that work on my Torino?
Old 04-19-2003, 04:44 PM
woodz428's Avatar
Troll Hunter
Arrow
Just by-pass the p-valve and get an adjustable aftermarket one, they sell for $50-$75 and if you convert to front discs or 4 wheel discs later you can just adjust it.
Old 04-19-2003, 10:04 PM
Post
all of the aftermarket p valves i looked at only had two lines coming from them and mine has four?? or am i just missig something
Old 04-19-2003, 11:02 PM
Post
http://www.mpbrakes.com/MP11.HTM
This is a link to a some pictures of Combination valves "sounds like what your needing".
joe
Old 04-20-2003, 05:14 AM
woodz428's Avatar
Troll Hunter
Arrow
Usually the valve is just plumbed in the rear line. You put the front lines on one circuitand then do a few stops and adjust the valve so that the brakes stop about equally with a little front bias.
Old 04-21-2003, 03:26 AM
Honorary Redneck
Post
sounds like the same prob I had on my camaro, it's a combination valve not just a proportioning valve, try contacting yearone.com, they might know if one of the mustang ones they do will work
Old 04-26-2003, 02:33 PM
woodz428's Avatar
Troll Hunter
Arrow
Pretty much all the combination valve does is have a pre-adjusted porportioning valve in the rear line and a sliding switch that triggers a light to let you know one side of the system has failed. It's not neccesary to have one except in a restored show vehicle.
Old 04-28-2003, 05:18 PM
Hellbilly Hotrods
Post
use the one off the mustang. itll work fine, according to what my torino friend said.
mike
