Proportions oppinions
My scratch build has been put on hold for a truck that I picked up at a very reasonable price. I have been doing some planning/measuring before cutting a thing and wanted to get some constructive thoughts. This is me playing around with the poprtions to get everything where I think it looks good. The bed is one area that I am undecided on, length wise. I don't like how long it is now, but don't want it really short either so this where I put it. Thanks for all thoughts.
Josh As purchased- Photo shop-
I think the bed needs to be a little longer, not much, and the rear wheel centered. To me it just ends to close there. Every thing else looks good.
Thanks, keep em coming. I am open to other people's ideas cause it makes me think. Thanks.
Try shifting the whole wheelbase forward. IMHO, the centerline of the front axle would look best at the centerline of the radiator/grill. Once you get the front located and are happy with the wheelbase dimension, then size the bed so it is centered on the rear axle like Underground said.
Based on the suggestions you guys gave I did this, this morning and I definitely like it better. The bed is not really any longer just looks so with the wheel base shifted forward to center the wheels. Let me know what y'all think. So far the thoughts helped me out in getting what I would really like down. Thanks.
That looks alot better. I thought it might look funny sliding the rear wheel forward. Kinda make the rear look to stubby an make the cab look to far back, thats why I didnt suggest it, but it works. I like.
I fiddled with it a bit today. Sectioned the body, more chop top, moved the engine forward a bit to allow rear distributor, smaller front tire, moved the rear tire a bit. Just another possible way to look at it.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Inset the firewall and allow the motor to set back farther. Better weight ratio.
CBoy that looks real mean, and I may run that much of a channel. I was looking at a four inch channel on the body, but the bed was only about an inch. I do like the look, i would have to do some real world math to determine what ride hieght that either of ours would get to. I just didn't want too low. Need at least 4 inch lowest ground clearance. Just to make it easy to drive, I opted for more with less of a channel. I am not worried about the headroom in the truck as the roof allows for a lot of head room, so we will see. Thanks for the visual work, I respect your work and am glad you chimmed in.
i do agree with underground though. This truck has a factory recess and that 4" to the back will help with weight transfer so I am going to keep the engine set back.This picture is a bad one but you can see the dark area in the middle of the firewall is set back a few inches.
Keep it long and low...short wheelbase lowered vehicle look funny
Aww, c'mon CBoy. Don't you want to fly down to Texas and help for free??? Just kidding ofcourse. The main thing I am actually still trying to figure out will have to be one of those, "when I get there" fixes. The front pillars have this really cool curvature right below them that I may(will) have to cut up to line them back up with the roof. I really want to put it back in so I will have to figure that one out. Otherwise the chop should go pretty good, not too terribly difficult.
Jim- thanks for your oppinion. I will say though if you are suggesting leaving the bed length stock, I have to disagree. That is not the look I am going for on this truck. An inch or two difference to get correct visual proportions, absolutely. But adding that extra 14" or so I cut out, I don't think so, I didn't like it. I did not start out cutting the bed. I lowered it down to about the stance and then looked at it and decided to cut a lot(but not as much as some) out. |
| Oppinions EQ lightening heads and EQ vortec heads | eatonde | Engine | 16 | 02-18-2013 11:00 PM |
| SBC 882 ported and polished... Good buy or not?? Need your oppinions on the porting | eatonde | Engine | 11 | 02-24-2009 01:46 PM |
| Proportions, it is all about Proportions. Customizing tips... | MARTINSR | Body - Exterior | 5 | 07-12-2005 11:50 PM |
| I need some oppinions | GoddessOfDaCRX | Hotrodders' Lounge | 18 | 09-17-2003 09:35 AM |
| Check this out. Oppinions please. | HemmiGremmie | Hotrodders' Lounge | 3 | 09-21-2002 12:41 AM |
