Propper Mph For Power Glide To Shift - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2009, 03:21 PM
I Have A Aluminume 67 Power Glide And A 283 Small Block Trying To Figure Out What Mph And Rpm Is Best For Shifting.its Shifting At 25mph Im Pretty Sure Originaly Shifted At 30 Mph.im Trying To Figure Out Whats Best For Transmission.
Old 02-02-2009, 04:04 PM
Joe G's Avatar
Registered user
Just a novice observation here, but...
Wouldn't the ground speed at which the transmission shifts depend on how much load the engine is under, the rear end gearing, and the tire size? Or maybe a Power Glide wasn't that sophisticated and you just set it to shift at a certain input RPM.
Just thinking out loud...er....typing...or...whatever. Thyping? Tynking? IDK...
Joe G.
Old 02-02-2009, 05:13 PM
Sorry Im Not A True Gear Head Such As Yourself.im Still Learnig All The Ends And Out.im Just A Car Lover Who Has A Classic Car That Im Trying To Restore My Self So Some One Like You Does Not Rip Me Off When Im Trying To Get A Simple Thing Done On My Car Like Ajusting A Shift Cable.i Come Here For Friendly Advice From People Who Know More About This Than Me.if My Question Is Below Some Peoples Standards Than There Is No Need To Reply.if Anyone Has Any Help Full Advice It Would Be Greatly Apperciated,smart *** Commintes From Some One Who Is Much More Knowldeable On The Subject Can Kiss My *****.
Old 02-02-2009, 05:28 PM
Power Glide Shift
Im Trying To Figure Were My Power Glide Trans Should Shift.my Car Is A 67 Impala All Originale And Stock It Has A 283 Small Block With Orginale Rear End (not Sure What Gearing But I Know It Hasnt Been Changed From Factory Gearing).15 Inch Center Lines For Rims With 285 Tires.i Recently Changed Intake And Carb To Edelbroc Perfomer Series.and Installed Lakor Throttle And Kickdown Cable.i Realize The Tighter The Kick Down Cable The Later It Shifts.can Some One Tell Me How To Figure Out Were I Should Be Shifting.for Best Life Of Trans
Old 02-02-2009, 05:35 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
If I am getting you correct.
The Down shift cable is for the "passing gear" on a power glide ... well there is not a lot of options for passing gear.
My 67 Bel Air 250 1 bbl Power Glide Would shift around 25 MPH normal & 60 ~65 MPH with the Go pedal matted.
My 66 Skylark 340 2 bbl Pwr Glide would shift about the same it would idle @ 20 MPH
Did this help?
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 02-02-2009, 05:48 PM
very help full thank you
Old 02-02-2009, 06:00 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
it would go by engine RPM not MPH, there are to many variables to pick out a standard MPH
there are also a lot of variables for RPM such as motor and tourqe converter
some more info on the car would be hepfull
and i dont believe joe g was trying to be a smart***
things just dont always come across a keyboard like they are intended
Old 02-02-2009, 06:03 PM
I don't understand?
oh now i see you reposted this with more info never mind
Old 02-02-2009, 07:16 PM
Joe G's Avatar
Registered user
Maybe I should have worded my last comment differently or used some smileys or somethin'.
Originally Posted by Joe G
Just a novice observation here, but....
I meant that I was making a novice observation. I wasn't saying you were a novice. Nor was I trying to knock your question, knowledge, abilities, etc..
I wasn't being a smart***, I was just saying that there are many factors that determine when most automatic transmissions shift. But Powerglides, being an early form of auto tranny, might work in a simpler manner for all I know (hence the calling myself a novice).
You question is a good one. I hope to learn more about how Powerglides work because of this thread.
Didn't mean to piss you off, Man.
Sorry.
Old 02-03-2009, 01:09 AM
Thank You Guys Were All Helpful To Me.joe Im Sorry For Jumping Down Your Throat,the Reply Did Help Me.thanks To All Of You Who Replyed.i Wiil Be Starting A Juarnale You Can All Check Out In The Next Few Weeks I Will Be Tareing The Hole Car Down And There Will Be Lots Of Pics.
Old 02-03-2009, 09:02 AM
I don't understand?
some people take things i say the wrong way in person (VERY DRY sense of humor) so i can be misunderstod on the computer VERY easily and often
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
140 mph over the speed limit! dinger Hotrodders' Lounge 38 08-07-2005 04:23 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 10:21 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
BOP Glide help olsixrod Transmission - Rearend 3 01-14-2004 07:27 PM
