pros and cons of a lightweight crank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2010, 09:48 PM
can anyone tell me the advantages and disadvantages of running a scat superlightweight crank in a street driven 383 chevy? i know you can rev a little quicker but are the gains worth it? thanks
Old 01-10-2010, 02:19 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
pro: lightweight
con: expensive
wallet: lighter
A lightweight crank is usually not recommended for the street. The real end result price goes up exponentially if 'heavy metal' has to be added to get a balance. Special bearings with provisions for the bigger fillets usually found on light cranks must be used. For the street, money is better spent on cyliner heads and durability.
Old 01-10-2010, 05:20 AM
engineczar's Avatar
While capable of freeing up some HP going to a lighter crank requires equally light connected parts to make it all work ie rods and pistons. Run of the mill rods and pistons won't get you near the bob weight needed to balance out. So like the previous poster said you'll end up having to add weight back onto the crank which is expensive and negates doing it in the first place.
BSE Racing Engines
Old 01-10-2010, 09:06 AM
makes sense!
thanks yet again!
Old 01-10-2010, 02:30 PM
candy63impala's Avatar
good info to know
moving rear rearward, pros and cons? leldai73 Suspension - Brakes - Steering 6 02-11-2008 06:23 AM
pros and cons for a shift kit stoney 81ta Transmission - Rearend 12 02-07-2008 02:45 PM
Pros and Cons of a T-5 or T-56 five speed? Hippie Hotrodders' Lounge 2 11-28-2007 04:45 AM
Methanol race fuel - pros and cons newchevyman General Rodding Tech 4 09-27-2004 08:27 AM
Block pro's and Con's carcobias2 Engine 1 10-27-2002 03:50 PM
