Pros and Cons of a T-5 or T-56 five speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 06:16 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Spent some time rowing the 5 speed in my kid's Ranger this weekend and now I'm longing for another stick. I was going to put a 200-4R in my Stude but there is also a really slick kit to swap a T-5 or T-56 into one using the stock 3 speed bellhousing. This is not a high powered car, it's light and will have skinny little tires so strength isn't that big of an issue. I like 200-4R's but I sure did have fun rowing a 5 speed again and it didn't bother my knee at all in traffic. I'd like to hear the pros and cons of the T-5. TIA.
Old 11-27-2007, 10:40 PM
Sounds like a good plan. Here's a little info on the T-5 that you might find useful: http://www.moderndriveline.com/Techn...t5_history.htm
Old 11-28-2007, 05:45 AM
Hippie's Avatar
Thanks Jim. Great info. Just thought of another "pro/con" in my application, the Stude mounts are set up like the Tri-5 Chevies. That means there would be a rather large span between mounts on the 200-4R whereas the 5 speed would still use the factory bellhousing mounts.
What are the pros and cons of Vortec heads? Slimpikins Engine 13 02-06-2006 03:17 PM
pros and cons of fuel pumps cobra513 Engine 7 07-22-2005 02:04 PM
Pro's and Con's of Positraction? Malibu73 Transmission - Rearend 54 06-04-2005 09:22 PM
Methanol race fuel - pros and cons newchevyman General Rodding Tech 4 09-27-2004 09:27 AM
Block pro's and Con's carcobias2 Engine 1 10-27-2002 04:50 PM
