ProSpray Clearcoat - How long to fully cure? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2012, 10:00 PM
Hello,
I just picked up my car from the body shop this morning and as I expected the clear is still alittle soft. Its been in the 60's and 70's the last few days and the car was just sprayed on Saturday.
With the current temperatures hovering around 70*, how long does it typically take for the clear coat to fully cure? Or can I expect it to be alittle soft until the 80* weather final makes it's way back to Indianapolis area? I had a drip nub hanging off the bottom of my fender I shaved with a razor blade and it was still rubbery.
Thanks,
Clark
Old 05-01-2012, 05:14 PM
Give it a couple weeks then cut and buff.
how long do you have to recoat clearcoat millermax Body - Exterior 3 05-01-2012 04:34 PM
How long to let poly filler fully cure before blocking 67Elcamino Body - Exterior 5 02-13-2012 10:34 PM
Prospray base has an 8 hour clearcoat window?? JohnnyK81 Body - Exterior 5 04-01-2011 10:49 AM
Paint Cure Time - How Long Should You Wait bigbrowndog Body - Exterior 3 04-14-2006 08:36 AM
How long should new concrete cure before painting cboy Garage - Tools 18 07-02-2004 03:06 PM
