-   -   protecting half dollar bare steel spots (http://www.hotrodders.com/forum/protecting-half-dollar-bare-steel-spots-188659.html)
glhx 12-04-2010 02:39 PM
i have some spots where the paint is gone all over my car. The surface rust is becoming deep pitted rust. I have taken most of this out using naval jelly so its bare steel again. i need to protect all these little spots. what is the best method.
spray can primer and spray paint after removing the naval jelly residue
200horse 12-04-2010 03:20 PM
are you going to paint it down the road? give more info on what you are planning to do with it
302 Z28 12-04-2010 07:53 PM
You can use the rattle can primer, but all traces of it will have to be removed before any serious steps toward a lasting paint job are attempted.
Vince
crussell85 12-04-2010 09:55 PM
rust-o-leum red oxide primer covered with a color of your choice
glhx 12-04-2010 10:35 PM
yes i am going to paint it with spi epoxy primer, then high build, nason red and clear. this is pitted stuff. Im really starting to hate pitted metal. you can't get stuff out of the pits. so if i paint it with rustoleum its almost impossible without sand blasting to get it all out really well. cant use straight primer. it will just rust through it
200horse 12-04-2010 11:28 PM
i would get all the black out. If you have to buy a small blaster and blast it. If you are on a tight budget i would use a rust inhibator primer that would be your next best thing.
but i would want all the black out of the pit then epoxy and fill
good luck
Jim Rockford 12-05-2010 06:42 AM
Yea I wouldn't waste my time with and spray can primer, Its porous and will absorb moisture and you will still get rust, spot blast and epoxy primer is the only right way to go.
deadbodyman 12-05-2010 06:45 AM
Vince
I woulld use some cheap paint insted of primer, those cheap rattle can primers will absoarb moisture
302 Z28 12-05-2010 08:47 AM
Good point DBM, thanks for pointing that out :thumbup:
Vince
