Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Protecting the starter on a sbc
Old 06-04-2006, 08:36 AM
LanceM LanceM is offline
Almost an old guy...
Had the same prob with my S-15/350 swap. Tried all of the above and finally went to a mini starter that I could rotate away from the hedders, that was the final fix. My 99 Silverado has a heat shield on it from the factory, so if you see one in a junkyard you could pull it off of one of them, it just pushes on.
Lance
