Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Be proud of your garage!
Old 06-22-2004, 03:55 PM
dmc12mk3's Avatar
dmc12mk3 dmc12mk3 is offline
Last journal entry: Fixed some leaks
I'm rather proud of my shop. When I bought the place (house, shop, and land) from my father you couldn't even walk around in the garage (30X40). With the help of my buddies, I've since cleaned it up (threw out his junk), put an opener on the center door, added outlets, a lift, and real lights. Next I'd like a big compressor to go outside in a shed and run some pvc around for some air take offs as well. These two pics are from opposite sides of the shop, but they are several months apart. Down the wall you can't see is just a long work bench with shelving above and below it.
The panels on the wall are from where I rolled the little car a while back.
