Be proud of your garage! - Page 29 - Hot Rod Forum : Hotrodders Bulletin Board
  #421 (permalink)
Old 01-10-2010, 10:05 PM
jmfalco's Avatar
Last journal entry: Original wood for Drip pan
Such as it is
Here's what I have.
Jack.
Name:	Shop in snow 2008.jpg
ID:	43164   Click image for larger version
Name:	Body & 389 new.jpg
ID:	43165   Click image for larger version
ID:	43166   Click image for larger version
ID:	43167   Click image for larger version
  #422 (permalink)
Old 01-10-2010, 10:48 PM
dmc12mk3's Avatar
Last journal entry: Fixed some leaks
Originally Posted by gilby246
2 car garage...about 800 sqft...and my 36 chevy coupe
Nice ride. Good looking work area too. Looks like you have made judicious use of this 'organization' thing I've been reading about. Metal working tools and an ability to make them do something on purpose is high on my want to have list.
  #423 (permalink)
Old 01-10-2010, 11:10 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
That photo of Jack's shop with the snow all around is spectacular.
Good things come in small packages.
  #424 (permalink)
Old 01-11-2010, 09:48 AM
dinger's Avatar
Originally Posted by jmfalco
Here's what I have.
Jack.
I would use the shop pic with the snow for a Christmas card. Nice!
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #425 (permalink)
Old 01-11-2010, 02:35 PM
jmfalco's Avatar
Thanks
C-10 & dinger,
I hadn't thought of that. If only the inside looked as good as the outside .
Jack.
P.S. That snow fall was Dec. 2008 and over the week it got to about 14". We haven't had any snow to speak of yet this year.
  #426 (permalink)
Old 01-25-2010, 06:10 PM
icsmannn's Avatar
MY "Hobby Garage" in Springfield, MO.
I decided to introduce a new business concept, a year ago, and am pretty happy with the way things have turned out. This is actually Beta Test Site #2 which turned out a lot nicer than the first.....and I keep adding to it! I haven't been able to purchase the 4 Post Lift yet.......but life goes on! I needed a place to "play" with my hobbies; therefore, I started "CrankShaftMotorCarClub.com". I describe it as "the Car Guy's Health Club". I'm not really running it like a full fledged business yet, but more like a way to justify buying some cool signs, painting it the way I always wanted to, and helping my friends with their rides while we cover the overhead of staying WARM! LOL! The Bathroom has a CamShaft with gears mounted on both ends, for the Towel rack, and the Tailgate Hinges, from a '49 Chevy Pickup, serve as the Toilet Paper Holder! I'm doing my best to tear things up and weld them back together. That's why THIS forum ranks pretty high in my list of "have to have" as I've found the answers to numerous issues that plague the average hobbyist who DOESN'T do it for a living!
  #427 (permalink)
Old 01-25-2010, 09:01 PM
ryork's Avatar
38 LaFayette
Last journal entry: Got a little help..
This is my garage I built last year..30 x 45. Should have been 60 x 90..
Never enough room. I learned a lot building this one.
<edit> It has two 8 foot drive in doors and a walk-in. 1 1/2 inch foil faced insulation. 75,000 btu propane stove keeps it warm when I can afford the propane Total cost to build including concrete was about $7500. It is a pole barn kit.
Bob
ID:	43448   Click image for larger version
ID:	43449   Click image for larger version
ID:	43450   Click image for larger version
  #428 (permalink)
Old 01-26-2010, 07:58 AM
aminga's Avatar
Last journal entry: Cleaning and Powder coat
I Inherited this garage from the previous owner and he did leave me with a nice starting point. He left me with enough electrical panel space to add outlet reels a welder, air compressor and oven.
But it was left with open floor joists that blocked off the lower section and left the upper unusable. So I had it floored now I have storage space for junk
  #429 (permalink)
Old 01-26-2010, 08:44 AM
ryork's Avatar
38 LaFayette
Verrry nice! It is going to cost a lot to fill that up with big boy toys
  #430 (permalink)
Old 01-27-2010, 06:13 AM
aminga's Avatar
Since access is limited to a set of pull down stairs it will have to be filled with a bunch of little toys.
  #431 (permalink)
Old 01-27-2010, 08:52 AM
ryork's Avatar
38 LaFayette
I was mainly talking about the bottom part, but it is great to have the storage area above. I have an old 40 x 40 milking barn with an area above for storing hay. The stairs are almost straight up and I know that once I took something up there it would probably never see daylight again. I thought about putting the woodworking stuff up there, but not sure how I'd get the heavy stuff up the stairs.
When I moved to Illinois I bought 10 acres of an old farm. It had three good outbuildings, but none are really suitable for a workshop/garage. All had dirt/gravel floors. The old equipment shed almost qualified, but it had an old fashioned corn crib down the middle. I had lots of rough storage area, but needed to build the workshop pictured in the previous post. You can see the start of the workshop in the picture of the redone equipment shed. The milk barn is concrete block and only has walk in doors. There is a two car garage but it is still filled with a 39 Pontiac, motorcycle trailers, and various bits and pieces accumulated over a lifetime.
ID:	43481   Click image for larger version
Name:	equipment shed 2.JPG
ID:	43482   Click image for larger version
  #432 (permalink)
Old 01-27-2010, 01:12 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Really nice looking place you have!
Any way to make a set of stairs to the upper level without hurting floor space on the ground level?
How do you like the metal roof?
I personally like the looks of them. Houses out in the country look good with metal, I have contemplated roofing mine with sheet metal but I am in the city and I am not sure it would fit in with the neighborhood????
  #433 (permalink)
Old 01-28-2010, 07:22 AM
aminga's Avatar
Not really. The biggest limitation is that the ceiling beams are on 24" centers. I have kicked around the idea of cutting a few of them and boxing it in to put in a trap door with a hoist to lift some of the big sutff up there. Maybe later
Another reason for doing this was to install a heater. The weekend it snowed the highs were 25. Made it a little hard to work out there.
I Love my metal roof. They put it on in Aug/Sept and I was at work in the upstairs home office. When they covered the section of the roof over my office it got noticably cooler. Plus where we're located it's prone to high winds (I've seen on guests over 80 MPH at least 3 times since we've moved) and I got tired of fixing shingles. Last year we put on the roof and replaced all the windows with Double pane Low E glass and our utilities are down by 25%.
let's see some photo's of the T. since Mine is also a 1 owner T.
  #434 (permalink)
Old 01-28-2010, 09:40 AM
dinger's Avatar
Aminga and ryork, I'd love to have that kind of country living! Beautiful surroundings, very nice. Now for the access to the second story, I have seen some nice stairways built on the outside of the building. You might try something on the end of the building. For heavier objects, maybe like they used to do the haybales in the old days.
  #435 (permalink)
Old 01-28-2010, 10:17 AM
ryork's Avatar
38 LaFayette
Originally Posted by dinger
Aminga and ryork, I'd love to have that kind of country living! Beautiful surroundings, very nice. Now for the access to the second story, I have seen some nice stairways built on the outside of the building. You might try something on the end of the building. For heavier objects, maybe like they used to do the hay bales in the old days.
The old milk barn does have the opening on the end but the hoisting system is missing. I guess it wold not take too much effort to rig up a hoist of some sort.
Country living is great until these 10 acres have to be mowed 5 or 6 times a month I'd like to fence it all around and turn loose a heard of sheep. It is 20 miles to the grocery store and gas station. I've lived in rural areas for the last 30 years. My last home of 27 years was three acres with woods all around and this one is ten acres in the flatlands of Illinois. Big difference. I'm on the last property before the river bottom crop land. There are several thousand acres to my north with no houses. I do have trees on my property. I cannot imagine living in town anymore. Seems like the houses get closer together all the time.
It's nice in the summer, but sometimes in the winter it is a little hard to get around.
Bob
ID:	43504   Click image for larger version
