ProVision fiber optic scope - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2006, 11:10 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
I don't have much experience with this type of tool, but this one caught my eye on Toolmonger.com the other day.
Review from Toolmonger.com: ProVision Eagle Fiber Optic Scope
Product information page: http://www.provision100.com/pvelite_eagle.html
It's being advertised as an inexpensive ($225) fiber optic engine scope.
Old 08-15-2006, 12:08 PM
powerrodsmike's Avatar
Wiki Edits: 161
I have a provision 636. It is not turned out to be as great as they made it sound when I bought it for 300.00.
The new product info for the "eagle" says it has better resolution , and a better light. A compliant 1/4" shaft is available on that unit also.
Those are several of the issues I have with my 636 that needed improvement.
If they have truly addressed those things then it could be a great tool.
I know that even with my old one I found metal chunks in a cylinder from a spark plug that disentegrated upon dissassembly. I would have not seen it with out the scope. That alone was worth the price I paid for the tool.
I also found some other internal engine mishaps on my hardly abelson that would have been otherwise un viewable.
I'd buy one if I didn't already have one.
later, mikey
BE different....ACT normal.
Old 08-17-2006, 01:50 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I have one very similar to the Provision, mine is a Flex View, but instead of a normal light on the end it has a blue light for finding A/c leaks using dye. Its great for looking inside the heater case at the evap core. I use it a lot and it works well after you get the hang of using it.
Steve
Carbon Fiber Driveshafts - are they worth it? Mad Maggot Transmission - Rearend 6 10-30-2005 03:46 PM
fiber glass VS metal Judd Lund Body - Exterior 11 09-22-2005 08:23 AM
Fiber Carbon Niks jcclark Body - Exterior 3 03-03-2005 09:17 PM
Steps in Laying out Carbon Fiber Vick Body - Exterior 2 10-22-2004 08:27 PM
How to on Fiber Glass Parts SnapCase Body - Exterior 10 05-23-2003 04:02 PM
