Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Prowler Orange
Thread: Prowler Orange
  #17 (permalink)
Old 05-15-2012, 08:12 AM
MARTINSR MARTINSR is offline
Originally Posted by bighotroddin
I have a 51 that I'm slowly working and another 65 Chevy fleetside for a friend and its pretty much impossible to paint the box bolted together. You have to hang the parts and unless your booth is the size of a airplane hanger you can't do everything at once.
Did you get your paint yet?
Yep painting the box together is a toughie. I split mine apart (48 Chevy pickup) and it did make it a lot easier. The bummer is the sides are welded to the rear crossmember, not just spot welds but a bead. I cut them apart and simply left the weld out. Worked fine, but I also never used it as a truck. If you were going to use the truck as a truck you would have to bolt it a little better or weld it or something.
