Prowler Orange - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-14-2012, 11:08 PM
4T9 4T9 is offline
No I just finished my final blocking and I'm planning on buying the paint this week.. I'm not having much luck uploading my pics on here but I'm sure ill get them on here soon . I've been jumping back and fourth between black and prowler orange and finally decided to go with the orange...
  #17 (permalink)
Old 05-15-2012, 08:12 AM
Originally Posted by bighotroddin
I have a 51 that I'm slowly working and another 65 Chevy fleetside for a friend and its pretty much impossible to paint the box bolted together. You have to hang the parts and unless your booth is the size of a airplane hanger you can't do everything at once.
Did you get your paint yet?
Yep painting the box together is a toughie. I split mine apart (48 Chevy pickup) and it did make it a lot easier. The bummer is the sides are welded to the rear crossmember, not just spot welds but a bead. I cut them apart and simply left the weld out. Worked fine, but I also never used it as a truck. If you were going to use the truck as a truck you would have to bolt it a little better or weld it or something.
I always get orange peel! I hate orange peel! shad9876 Body - Exterior 15 10-14-2008 08:45 AM
eagle scat cat legend prowler, whats the difference? 406 ss monte Engine 4 12-01-2007 05:02 PM
Anyone heard of prowler rods? HemmiGremmie Engine 0 09-16-2002 02:11 PM
Prowler brand connecting rods americanfreedoms Engine 2 09-05-2002 04:14 PM
'36 Buick with Prowler Headlights - Any helpful hints? hurtem90 Body - Exterior 0 02-05-2002 02:34 PM
