PSI and GPH!!?
I'm working on putting a vortech supercharger onto my 400 SBC. I'll be using a quick fuel 750cfm carb, I ordered my regulator that offers a wide range of future upgradability.
But, what I dont know what GPH I will need- or how that works... So far I have done enough homework to know that for every pound of boost I make I need +1 PSI, so I plan on making 8-10 PSI which means the fuel pump i picked max's out at 16psi so if i do make 10 psi i should be perfect. HOWEVER!! i see all these fuel pumps make different GPH, The fuel pump I picked is the fallowing part number: HLY-12-150 (summit part number). If someone could please explain what i need and why i would be so greatfull! If it helps my engine specs are the fallowing: 408 SBC - patriot freedom headers 175cc - comp cams nostegla 50/50 cam- 9:5:1 compression with SOON TO BE vortech supercharger 8-10 PSI. Being over optimisted Id love to see close to 600 horsepower Last edited by djohnson308; 02-10-2013 at 09:25 PM. |
A 500hp engine needs 50GPH fuel @ WOT. Most Fuel pumps are rated for free flow, not the flow at the working pressure thru a orrifice. So you cannot tell the true flow from the rated flow.
Bench testing is the best way to get it all , right. |
| Tags |
| efi, fuel pump, pressure |
| Oil psi and not so much psi | gongchuan | Engine | 19 | 09-10-2012 07:47 PM |
| Quick Fuel 30-125 125 GPH Electric Fuel Pump | 64gto71cobra | Engine | 1 | 04-27-2011 11:25 AM |
| how does gph match with Hp | malibu68 | Engine | 4 | 08-09-2006 10:00 PM |
| what kind of fuel pump and GPH | red_rider52 | Engine | 5 | 01-18-2006 06:38 PM |
| gph for a fuel pump?? | fireforsin | Engine | 12 | 10-14-2004 06:43 AM |
