PT Cruiser V8 Convertion - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-04-2007, 08:38 AM
PT V8 Conversion
Howdy, I dropped a big block dodge into my 2002 PT. I used the tube frame, front clip and drive train from a '73 jensen interceptor. I wanted the car to look stock so serious mods to the jensen chassis was needed to move the engine forward and get the steering to work. The Jensen works because the front track is less than an inch difference and the rear track is basically identical. I had to lengthen the drive shaft 28'' and get rear springs fabricated. I've got some work left with fabricating exhaust headers (I think the 426 max wedge headers will work), new gas tank, and installing the radiator, in the rear. no room up front any more. I did nothing to the firewall only to move the master cylinder more out board to clear the valve cover. I took a 2.7 T engine emblem from an audi and reversed it, turned the T upside down and cut a bar of the T. so on the back door is 7.2 L almost looks factory. Still have a ways to go, but so far so good. TLMcB.
  #17 (permalink)
Old 10-29-2007, 11:31 AM
V8 PT Cruiser
Mark, I did build a V8 PT that I call the Bruiser. 5.9 liter Dodge V8, tubbed out with Mickeys stuffed under it hooked to the Ford 9", 4.85 gear and a third seat between the tubs. The article about the guy in Cal building them I think is BULL. Lots of things he said didn't work. He said he swaps the front Struts from side to side to allow for the Oil pan on the v8's, putting the steering rack in the front. That does not work. We are trying to solve that problem now. If you are still interested, E-mail me.
Clark
The Following User Says Thank You to Bigdog901 For This Useful Post:
PT TURBO (01-22-2015)
  #18 (permalink)
Old 10-30-2007, 02:04 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Sometimes bringing up the dead ain't so bad. I kinda liked checking out the 8 second Pitiful Thing lol.
Appropriate for Halloween......Thread Zombies!!!
