its been a long time, I dont remember except I do remember it was a pain in the butt
Get some transmission assembly lube. You can get it at NAPA. Separate out the balls into lite ones and dark ones (they are different diameters if you can't tell by color on a box so old). Use lots of grease to hold the balls in and put them in dark,lite,dark,lite, etc.
Thanks. The manual mentioned black and silver ones, I have them sorted by size, 12 each. If this sounds right, looks as if I should put the worm into the piston, thn insert the balls, with the lube into the hole under the return guide, and then install the guide and the last few balls with more of the lube.
-jwk- |
Sounds like you got it to me.
Check this out...
http://pirate4x4.com/forum/showthread.php?t=570869 |
The only thing that is different from my 71 K5 is that my steering box mounts on the outside of the frame rail and the 88-up mount on the inside. I do believe that there were minor part and setup differences over the years but the basic assembly is the same for just about all the Saginaw boxes...at least all the big boxes I have messed with.
Mine is a '71 Mustang box, and the guts appear identical. Only difference was the sector cover gasket. Mine is a o-ring whereas the one pictured is a flat one. I have also heard that the whole inside of a later Vette box will drop into these early Ford ones.
| test Ball's remote transmitter and receiver | GMR | Electrical | 29 | 04-08-2007 10:47 PM |
| ball's power windows kit | william r plise | Hotrodding Basics | 3 | 08-17-2006 09:40 AM |
| Using old rocker arm balls as thick washers for positive stop studs? | Dubz | Engine | 10 | 01-02-2005 02:04 PM |
| Ball's Rod and Kustom | Bill Ford | Electrical | 1 | 01-20-2004 05:48 PM |
| HELP! My TH350 has puked! | The Vandal | Transmission - Rearend | 3 | 11-05-2001 06:29 PM |
