pukeing fuel out the filler neck - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2005, 12:49 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
He Y'all
79 F150 460 4bbl C-6
dual tanks
no emission's
totally stock unmolested
All Ive donr to this truck was pull the rear tank and drain out about 5 gallons of stale gas when ever I park and there is the slightest lean to the drivers side it will puke gas out the filler neck
there is no emissions no canister systems on this truck and has only has one hose for the fuel line and a vented gas cap
I also only fill it until the pump clicks and still if i go into a store i come out and gas is all over the parking lot
so W T F???
as always thanks in advance
SR66
I'm not prejudice, I hate everyone
"SlowRide66"
"Illegitimis non carborundum"
Old 12-04-2005, 06:56 PM
30desoto's Avatar
Dodge ain't all bad
Rob
The only thing that comes to mind is the vented fuel cap is bad and not venting properly, or maybe you need to put a vent in your filler hose and vent under the truck to stop the pressure build up.
And don't feel bad, I'm not paranoid, everyone is just out to get me.
30dee
Old 12-04-2005, 07:01 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I was thinking the vent on the filler neck also, if it has one it could be stopped up .
Old 12-04-2005, 07:20 PM
jeeptuff's Avatar
**** or get off the pot
I second that..
Old 12-04-2005, 07:50 PM
Rob Keller's Avatar
Wiki Edits: 38
ok how about where it goes inbetween the bed and the frame where the rubber hoses are ovaled to get to the tank?maybe pinched??
where could I put a vent?there if one hose out (fuel line)
fill tube&
3/4 senr tube that routs back to the fill tube
If i put a non vented cap on it it will create a vacume and suck the tank to either collapes or a vacume lock
i tried switching caps
SR66
"SlowRide66"
Old 12-05-2005, 10:01 AM
How close is your exhaust to your tank? I know this is a problem with stock Full size jeeps.
Old 12-14-2005, 07:35 PM
Rob Keller's Avatar
Wiki Edits: 38
far away right where the ford motor company left it
i dont get it its one frigging stock
SR66
"SlowRide66"
Old 12-15-2005, 08:07 PM
you said you have duel tanks , do you have that problem with both or just the rear tank? the problem is definitly in the ventalation but im not sure how those stock tanks are vented. i would think that ther would be a vent hose back up to the filler neck and the cap would be vented. if this is the stock set up then there is a obstruction in the vent line. you said you have already changed caps so we can eliminate that.
Old 12-16-2005, 07:21 AM
Rob Keller's Avatar
Wiki Edits: 38
Yes sir!! bone stock unmolested truck
it has 3 hoses thats it
the pick up tube /fuel line
the big filler one
and a little vent next to it it seems to be un obstructed because while fueling it when getting to full it will squirt out the vent back into the tank
makes me wish I could put some kind of check valve on the cap it couldn't be any simpler
the only thing I did out of the ordinary is I put a water separating marine fuel filter after the divert switch but if that was the cause it would do it only with the rear tank off
at this point all I can figure is where the filler tubes go from /to in between the frame and the body of the bed
not only does it such to come out and find my gas on the ground it dangerous im afraid some stooge is gonna throw a match in it thinking it water
SR66
"SlowRide66"
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
Fuel filler hose for 1977 Chevy C20 Terje Engine 0 07-18-2004 09:52 PM
1988 Olds Cutlass Ciera Filler Neck Hoses chevracing2003 Body - Exterior 0 08-19-2003 09:15 AM
FUEL FILLER for street rod truck OLEB97 Hotrodders' Lounge 3 06-21-2002 07:09 PM
