Pull engine vs pull engine and trans together - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2013, 07:33 PM
406 bug's Avatar
9.82 @ 139mph
Wondering what would be easier. Need to do engine rebuild on 67 ford f150 ,v8, automatic. I'm thinking it would be eaiser to pull eng and trans rather than seperate and just pull engine. Would appreciate opinions.
Thanks in advance.
Old 04-15-2013, 08:38 PM
My suggestion is to take it all at one time. the payoff will be with the re-installation. Once it is all back in place and the mounts are tightened all you have to do is check the shifting linkage and button up the universal joint. Everything is easier to access on a bench than from underneath. Just my thoughts.
Normbc9
Old 04-15-2013, 09:37 PM
Lilsmokey's Avatar
I also pull both on my truck, of course I really don't have a choice tho lol
Old 04-16-2013, 03:40 AM
On most 2WD trucks its better to pull both as a unit, but you will need to use a cherry picker that lets you angle the assembly as you pull and reinstall. If it was a 4WD with a heavy transfer case you often pull just the engine.
Bruce
Old 04-16-2013, 04:30 AM
poncho62's Avatar
Wiki Edits: 5
Depends what you want to do...If you want to clean/inspect tranny, I would pull both. If its a manual trans, I would pull both. Too big a pain to line clutch up while in car. When I was just pulling engine, I would hold the tranny up in place with a piece of chain looped up on the firewall.
The Following User Says Thank You to poncho62 For This Useful Post:
1Gary (04-18-2013)
how to pull JY engine? matt167 Hotrodding Basics 5 03-15-2011 09:19 AM
How to pull the engine Furytom General Rodding Tech 8 06-27-2008 06:42 PM
about to pull engine? bonzipenguins Engine 10 12-02-2006 11:57 PM
how do I pull my engine hotrod34 Engine 11 06-17-2006 07:14 PM
Engine Pull ve3ham Engine 5 06-01-2005 08:46 AM
