pulled cam needs timing.ext help!!! ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2003, 05:40 PM
Red face pulled cam needs timing.ext help!!! ?
i have a chevy with a 327.im pretty new at these so my question mite sound easy but if confussing the hell out of me.i pulled my cam without setting exactly were i pulled it out same with the distr... im placing in a new cam and lifters.i read u should run the eng over 2 rpm's for at least 30 mins the first time u start it with the new cam.but how can i do that if the timming of.is there anyway to set the timming before i start the eng? one more thing i screwed up on is removing the lifters.they would not come out so i put a long peace of clean cardboard in were the cam went so they wouldnt fall down the eng.well it worked.except the last one... fell down the eng.im hoping it ended up in the oil pan.anyone know? thank you if u left any suggestings.peace!
Old 02-04-2003, 07:11 PM
MI2600's Avatar
Member# 3287
Post
I hope you aren't using your old lifters with a new cam. If so, stop! You'll ruin the new cam.
Old 02-04-2003, 08:07 PM
Post
[quote]Originally posted by impala dreaming:
<strong>i have a chevy with a 327.im pretty new at these so my question mite sound easy but if confussing the hell out of me.i pulled my cam without setting exactly were i pulled it out same with the distr... im placing in a new cam and lifters.i read u should run the eng over 2 rpm's for at least 30 mins the first time u start it with the new cam.but how can i do that if the timming of.is there anyway to set the timming before i start the eng? one more thing i screwed up on is removing the lifters.they would not come out so i put a long peace of clean cardboard in were the cam went so they wouldnt fall down the eng.well it worked.except the last one... fell down the eng.im hoping it ended up in the oil pan.anyone know? thank you if u left any suggestings.peace!</strong><hr></blockquote>
i got new lifters.ty.
Old 02-04-2003, 08:35 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
You didn't leave the cam in when pulling the lifters? I hope you don't have too big a problem fishing that lifter out. When you get the cam in, don't leave it with the dots facing each other and try to stab the distributor, turn the motor one full turn first. With the dots aligned, it will be on #6 power stroke, not #1. This is a very common mistake for people being 180 off after installing a cam. That and problems with adjusting rockers (will be on overlap on each cyl.).
