Pulled my motor down, pistons say H-60-A, what are they? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 09:48 AM
ChevelleSS's Avatar
496 BBC, TH400 12 bolt w/ 3.73
Hey guys, just wondering what pistons I have in my motor. They say H-60-A on the back, I believe they are Aries. What compression ration would I be looking at with my set of 781 118cc oval port heads? Thanks for the help pepes! Mike
Old 07-11-2010, 07:18 PM
ericnova72's Avatar
More for Less Racer
The H-60-A is just a forging identifier, it is likely Arias, like all piston makers, makes several different pistons from this same forging blank depending on how the dome size is cut, valve relief size, ring groove package, etc. It will be impossible to identify by just that #.
Arias will be able to tell you what it is if you completely measure all(or just several) features of the piston dimensionally and call them.
Old 07-12-2010, 09:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you end up w/the heads off, there may be a useful number there.
Opinions needed, Dished or flat top pistons _titan_ Engine 46 04-28-2010 04:28 PM
identifying pistons?? 2wld4u Engine 12 01-15-2009 11:29 AM
Wiseco Pistons radracer43 Engine 3 09-11-2005 08:28 PM
Help with pistons sotxpanrider Engine 4 04-30-2005 01:29 PM
What pistons do you suggest? Frisco Engine 4 11-13-2003 10:29 AM
