Pulled rocker stud, and more? :( - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-21-2007, 07:40 AM
T-bucket23's Avatar
Wiki Edits: 26
If he just fixed the stud in the first place he probably would not have wiped out the cam.
  #17 (permalink)
Old 03-21-2007, 04:31 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by Gokussj5okazu
Are there any particular problems with running it on 7 cylinders, other than the horrible balance? I really don't care about bearing wear or anything else, as long as I can get it out there. We're most likely going to just finish up my other engine.
Doc here,
Oil contamination, rapid wear from metal shavings, main and rod Bearing wear, more cylinders going away, cam shattering, or locking up, are just a few..you STILL could end up walking that 15 miles AND then need a tow Vehicle..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
  #18 (permalink)
Old 03-22-2007, 04:53 PM
Gokussj5okazu's Avatar
Last journal entry: 336 Stroker: Teardown
Alright, thanks for the input. This is the engine that came in the truck when we bought it. We origionally thought it was bone stock, but once we removed the right valve cover we noticed the heads were extremely clean so we know atleast those may have been rebuilt. Anyhow, the #4 INTAKE rocker stud was pulled, AND the #4 EXHAUST cam lobe was wiped the first time we removed the valve cover. Just for the record, we did get the #4 intake stud fixed, no more pulling. We got it running rather decently today, and plan to drive it out to my shop where it will sit until the new engine is done. I really don't care what happens to this one, heck I believe a main bearing is bad anyhow, considering what I could hear before this fiasco. Thanks everyone, here's to the biggest PITA ever.
Btw thanks for the link Doc, that'll do.
